Headlight Modulator and Low Beam HID - BMW Luxury Touring Community
Thread Tools Display Modes
  #1
Old May 8th, 2007, 10:33 pm
ihbond ihbond is offline
So many of you know I have sold my k1200lt. I was asked if I could install a LOW BEAM Hid. so here goes a couple of questions
1) If you had a total of 10 days to order plus install..where would you purchase the LOW beam HID from ? (http://www.cqlight.ca/) ?
2) Any issues using a lowbeam HID and Modulator ?
(I know the modulator works off the high beam)...wondering about surge\pulse and if it would screw up the HID..
3) 2004 k1200lt I just need to replace the H7 Bulb ? So if I order from cqlight, just ask for H7 replacement ?
Thanks...
Old May 9th, 2007, 6:37 am
PMitchell's Avatar
PMitchell PMitchell is online now
"2) Any issues using a lowbeam HID and Modulator ?
(I know the modulator works off the high beam)...wondering about surge\pulse and if it would screw up the HID.."
A BIG issue . . it won't work. The HID bulb needs full voltage from the ballast to fire and the modulator pulses from just a twinkle to full voltage on a timing cycle. They are incompatible.
__________________
pm
Life is too short to do anything
other than that about which you
are absolutely passionate . . .
Ride till you can't!
"Der Weg ist das Ziel"
Morocco!
South Africa!
Spain, Tuscany, Provence & Andorra in 2012
Greece Fall 2013
In July, to The Dolomites of Italy, Alps of Switzerland & Austria and returning to Milan via the "Gold Coast" of the French Riveria.
'00 K1200LTC
'90 K75
'62 R 50/2 (Rode hard and put away wet)-Sold in '81
'63 Vespa 150 (1st and only dirt bike!) Sold in '67
  #3
Old May 9th, 2007, 6:55 am
atrovarious's Avatar
atrovarious atrovarious is offline
http://www.cqlight.ca/product_info.php?products_id=73
Is the above the right product to order? Assuming you want a bit of blue?
This is the install I think.
http://www.bmwlt.com/forums/showthread.php?t=18357
__________________
Ghaison (Jason)
99 K1200RS Silver and Blue (Sold!)
2004 K1200LT FOR SALE!!!
Bluefield, VA
Sometimes you can get so fixated on the fact that you are right that you lose sight of the reality that it doesn't matter.
-some guy named Ghaison circa 2002
What I'm thinking right now.
  #4
Old May 9th, 2007, 7:55 am
patroa1's Avatar
patroa1 patroa1 is offline
There is no problem running a HID low beam and a headlight modulator. As you said the modulator runs off of the high beam so no problem, mines set up that way and works fine, the only problem would be if you had an HID high beam.
As for where to get HID I would say http://www.fashtek.com H-7, 4300k for $75 just use the info from old group buy, not the web site ... or http://www.cqlight.ca/product_info.php?products_id=73
__________________
Pat Rourke
White Lake,MI.
2002 K1200 LTC, Champange
  #5
Old May 9th, 2007, 10:14 am
was's Avatar
was was is offline
Correct. I run both on my '99, never had an issue.
__________________
Bill
Guilford, CT
'99 Canyon Red K1200 LT - Buddah Bike
  #6
Old May 9th, 2007, 12:16 pm
PMitchell's Avatar
Perhaps a clarification is due for my prior comment. . .
As others have correctly stated, a hi-beam modulator can be used with a low beam HID.
The HID system (Hi-beam) cannot be used with a modulator for the reasons previously stated.
__________________
pm
Morocco!
South Africa!
Greece Fall 2013
'00 K1200LTC
'90 K75
  #7
Old May 9th, 2007, 12:36 pm
PMitchell's Avatar
Modulator Topics
My curiosity cat got involved after re-reading these posts
from Kisan:
pathBlazer Notes
■ PathBlazer modulates high or low beam
■ Plug & Play installation for most bikes
■ Adjustable daylight sensitivity
Also This
Just surf'n this afternoon after a busy morning.
__________________
pm
Morocco!
South Africa!
Greece Fall 2013
'00 K1200LTC
'90 K75
  #8
Old May 9th, 2007, 1:20 pm
dshealey's Avatar
dshealey dshealey is online now
No problem running a modulator on High, with HID on low. That is the way I had mine. Modulators are much better on High beam anyway, that way you have control of when to use them in daytime.
__________________
I don't want to achieve immortality through my work...I want to achieve it through not dying.
David Shealey
Dandridge, TN
EX: '01 Black LT, BAT BYKE (Totaled at 110,000 miles)
IBA SS, BB, BBG, 10/10ths.
No bike now, but maybe in the future.
  #9
Old May 9th, 2007, 4:39 pm
thanks everyone..
Thank for the re-assuance
Here is the Headlight modulator law if anyone ver cares
http://www.webbikeworld.com/Motorcyc...lator-regs.htm
You may not post new threads
You may not post replies
Forum Jump
