BMW Motorcycle Fuel Pump Bypass Cable - BMW Luxury Touring Community
 3Likes
  • 1 Post By corrcullen
  • 1 Post By lkraus
  • 1 Post By Joe's '06 RT
post #1 of 17 Old May 17th, 2017, 7:54 am Thread Starter
Was thinking of buying a BMW Motorcycle Fuel Pump Bypass Cable for my 2007 R1200RT as a precaution in case of a failure when am touring.
I was wondering if it is safe to plug it into the accessory socket, considering it only allows 5 amps?
I wondering if the fuel pump draws more than 5 amps?
https://burnsmoto.com/products/bmw-m...p-bypass-cable
Advice appreciated.
corrcullen is offline
post #2 of 17 Old May 17th, 2017, 8:11 am
mtrevelino's Avatar
Re: BMW Motorcycle Fuel Pump Bypass Cable
As I did, I just purchased a new one, installed it, and threw the old one in the side case. Or, you can buy a new one and store it in your side case for when and if the old one goes out. If the old one breaks, I cannot see the purpose of installing the bypass cable (spending funds) and then having to buy (more funds) a new fuel pump controller.
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #3 of 17 Old May 17th, 2017, 8:46 am
PadG's Avatar
Advice appreciated.
You can do what Mike suggest, or if you search this forum, in the RT section, you will find plenty of data of what and how to prep, without buying that cable! I had my '07 wired up ready to go, in the event that the FPC ever died, but never had to use it.
Pad. Gajajiva
Solon, OH, USA
2007 R1200RT (Sold!)
Once Upon a Time........
1963 Norton Dominator 650 SS
1960 Triumph Thunderbird (6T)
1952 Triumph Thunderbird (6T)
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #4 of 17 Old May 17th, 2017, 8:47 am Thread Starter
Fair point, that is my other option, just more expensive.
I think I'll just buy a new controller!
beech likes this.
post #5 of 17 Old May 17th, 2017, 9:10 am
lkraus's Avatar
My toolkit includes about four feet of 16 gauge wire, four Posi-Taps, and a printed copy of the attached wiring reference, which is also stored on my phone. Together, I should be able to rig a bypass using the existing wiring, but without cutting up my wiring harness. The parts are cheaper than the burnsmoto jumper, take up a little less room than the jumpers I've seen and have alternate repair uses.
Larry
2006 R1200RT
lkraus is offline
post #6 of 17 Old May 18th, 2017, 7:56 am
hopz's Avatar
There are (were) many references to guide you in making a FPC bypass cable at home. Not a big deal. Google will find them and maybe Youtube....
But I digress... Take the left side tupperware off and look at your fuel tank and the area around the FPC. The issue was/is cracks in the flange "thingy" (sorry for the technical term).. but if its cracked or leaking or smells of fresh fuel go to the dealer. I think there is/was a program or maybe Service Bulletin on the matter with free repairs... heck, you can even use the phone and call them.
or am I imagining all this? I am pretty sure I had a tiny crack in the collar of my '05 and that the dealer fixed it chop-chop... no charge.
2014 R1200RT WC
"It can prove difficult to reason with desire."
hopz is offline
post #7 of 17 Old May 18th, 2017, 10:29 am Thread Starter
Thanks Hopz, I always appreciate reading your advice & helpful comments on this forum.
The fuel pump flange, which can crack is a separate weakness in that area, I have the collar fitted over it, so that precaution is already taken.
The failure of the controller on top of the pump seems to be reasonably common, from what I have read.
It suffers from corrosion if water gets in, or is not monitored & kept clean.
I check it yearly, remove & clean it, as well as lubricating the seal, but was thinking of having a spare in case of failure.
post #8 of 17 Old May 18th, 2017, 10:52 am
PadG's Avatar
Since you do a lot of long rides, I do think that getting a new FPC would be the wise choice, in particular to ease your mind. Otherwise, making a bypass connection in an emergency on the road is very easy to do. I happened to opt for wiring power up to the general area, but you can easily tap into the main fuel pump circuit for the power and connect that to the pump-side of the FPC, in the event of failure. That's why Larry keeps a length of conductors and several posi-tap connectors as part of his toolkit! BTW, if you do get a new FPC, do make sure that it's the "improved" one, with the black powder-coated finish. DO keep the old one handy, on the bike for spare, since even the improved one are also known to fail!
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #9 of 17 Old May 18th, 2017, 9:53 pm
lkchris's Avatar
The 5 amp thing only applies to the first couple years R1200RTs.
The system was upped to 10 amps by, I think 2007.
Kent Christensen
Albuquerque
lkchris is offline
post #10 of 17 Old May 19th, 2017, 9:44 am
NoelCP's Avatar
Is the FPC something to concern yourself w/ on the waterboxer RTs? I'm reading references to older models so wonder about that.
2016 R1200RT - Platinum Bronze
2013 F800GT - Sold
1986 Identical Twin Daughters -
1985 Kawasaki 1000 LTD - Sold
1968 Honda 350 - Sold
NoelCP is offline
post #11 of 17 Old May 19th, 2017, 10:28 am
bandytales's Avatar
Hi Noel, as far as I can see, there is nothing to concern yourself about wrt the Wetheads. Their track record seems impeccable (thus far)!
bandytales is offline
post #12 of 17 Old May 19th, 2017, 10:57 am
rattler50's Avatar
Are you wiring around one of the connectors on top of the tank? The dealer is installing a new pump assembly on my 06 RT right now and it's under warranty. Are both of these connectors on top of the tank?
2005 K1200LT Ocean Blue
2003 K1200LTE Black
Totaled Oct 2, 2010
2006 Kawasaki Vulcan 2000
rattler50 is offline
post #13 of 17 Old May 19th, 2017, 12:42 pm
lkraus's Avatar
There is a nice illustrated FPC replacement guide here: R1200RT (all years) FPC Replacement Mini-Guide - BMWSportTouring Forums
The one in the pictures is newer black one, the early silver ones are the most troublesome. The FPC regulates fuel pressure by controlling the pump (I think it slows the pump by reducing the voltage, but it may just cycle the pump on and off). When the controller fails, the bypass is a temporary measure to provide constant power to the pump at the blue connector under the controller.
If the dealer replaces the fuel pump, they will transfer the FPC to the new pump, as the controller is a separate part and not included in the recall.
rattler50 likes this.
Larry
2006 R1200RT
lkraus is offline
post #14 of 17 Old May 19th, 2017, 1:57 pm
rattler50's Avatar
So, if I have this right, in order to bypass the FPC you wire the blue plug underneath into the black plug on top to make the pump work. Is this a common failure and would it be wise to carry a spare?
2003 K1200LTE Black
Totaled Oct 2, 2010
post #15 of 17 Old May 20th, 2017, 7:02 am
I was on a trip last year with a few guys and one rider on a new-to-him '08 RT had an FPC failure. He had a new GS911 along but no jumper or spare FPC. Eighty mile tow back home, thanks AAA!
The rider with the failed FPC bought two pre-made harnesses that connect to SAE connector and gave me one for my '06. I bought two used eBay FPCs that bench-tested good so we both have a spare.
My take on it is if you do not wire in a harness that can be activated without removing plastic, carry a spare FPC. Swapping-out an FPC on the side of the road is a less than thirty minute job.
All that said, I carry both my spare FPC and the harness. I know the odds of needing both are very low, but I've got them in my travel kit.
Joe
Joe's '06 RT is offline
post #16 of 17 Old May 21st, 2017, 10:30 am
rattler50's Avatar
Joe
In reference to your mention of the GS-911.............is that needed to diagnose an FPC failure? Or could you do it with a test light?
2003 K1200LTE Black
Totaled Oct 2, 2010
post #17 of 17 Old May 22nd, 2017, 1:54 pm
I'll bet a simple circuit test light would work IF you knew a good starting point; if I remember correctly the GS911 indicated a fuel pump failure. Photo is the towing rig sent by AAA: modified Chevy Caprice wagon with shop-made trailer was awesome!
Joe
Human Verification
R1200RT Fuel pump flange Sharon RT Series 4 Sep 6th, 2014 2:36 pm
Fuel pump issue on 2001 k1200LT Gizmoguy K1200LT 9 Aug 27th, 2014 12:28 pm
Fuel Pump Whine haunaben K1200LT 11 May 21st, 2013 11:42 am
Fuel Injector cleaning-on the bike PhillWard Australia, New Zealand, and AsiaPac 4 Nov 28th, 2008 12:02 pm
Fuel pump fuse blown RealWing K1200LT 9 Nov 24th, 2007 8:37 am
