2011 Engine protection fitted - BMW Luxury Touring Community
post #1 of 6 Old May 15th, 2017, 12:31 pm Thread Starter
Iscadean's Avatar
The GS guys have an engine protection 'bash plate' fitted as standard and I understand why this might not be necessary for the RT. However, I fitted a GS bash plate under my RT this weekend to ensure, when touring, that stones and other road detritus don't fly up under the engine causing potential damage. I had read somewhere on the forum that others had experienced under engine damage by stones and bits of metal. Fitting was very easy and took only 20 minutes. The plate came from Estonia, purchased on an auction site and was as new with not a mark on it. I needed a couple of nuts and the two rear flexible bolts from BMW but total cost fitted was about 50($64). Peace of mind now when riding.
The older you get, the more you know and the less you need.
1966 - Lambretta LD 150
1968 - Triumph Tiger Cub
1969 - BSA Shooting Star 500
1977 - Honda Superdream 250
1980 - Honda CX500
1995 - Yamaha VX1100
2011 - BMW R1200RT SE
Iscadean is offline
post #2 of 6 Old May 16th, 2017, 3:13 pm
Re: 2011 Engine protection fitted
Someone on the old R1200R forum hit something a few years back and punctured the oil filter. Left him stuck on the side of the road if I remember right. Will it cover the oil filter area?
Rascal is online now
post #3 of 6 Old May 17th, 2017, 4:51 am Thread Starter
Iscadean's Avatar
Yep. Does what it says on the GS tin since it's the same engine as the RT, same oil filter and drain plug, same threaded screw holes. Looks the business for 50. Of course when it goes in for a service the service guy will have to remove it to do the oil filter, etc. but an extra ten minutes on the labour sheet will not break the bank when I'm paying for a 12000 service and I do my own oil changes at 6000 miles. I'll find some pictures of it fitted.
Iscadean is offline
post #4 of 6 Old May 17th, 2017, 8:54 am
6speedTi's Avatar
I installed a OEM GS skid plate on my 2012 RT about 4 years ago. One of the best protection upgrades I ever did. Oil changes take a little longer to perform but it's no big deal.
2012 R1200RT
1985 T5 Vespa
2007 Piaggio X9 500 EVO
6speedTi is offline
post #5 of 6 Old May 17th, 2017, 9:26 am Thread Starter
Iscadean's Avatar
As promised. Looks good and seems as if it won't interfere with the lean angle.
1980 - Honda CX500
Iscadean is offline
post #6 of 6 Old May 17th, 2017, 12:46 pm
Pretty cool!
Human Verification
Mandatory tip-over protection is required for the GTL (You've been warned!!) k1600_ryder K1600GT/GTL 55 Nov 30th, 2015 4:32 pm
Does engine braking save brakes? brianRTnc RT Series 33 Jul 29th, 2015 11:15 pm
Best Engine and Bag Protection Bars tonyn1 K1600GT/GTL 11 Apr 18th, 2015 8:14 pm
Engine guard for GT 1300 ? 7seas10 K1200/1300GT (The Next Generation) 5 Jan 19th, 2011 1:55 pm
Engine washed - from inside! pozo_izquierdo K1200LT 12 Sep 11th, 2008 3:57 pm
