Hex ezcan on 2017 RT - BMW Luxury Touring Community
 4Likes
  • 1 Post By Silver Rat
  • 1 Post By lkraus
  • 2 Post By bikerdudekc
post #1 of 14 Old May 14th, 2017, 5:07 pm Thread Starter
I"m trying to find where to plug in hex ezcan into the canbus system on my 2017 RT. Has anyone done it and can you show/tell me where to plug in at?
Thanks, Steve
sattwood1633 is offline
post #2 of 14 Old May 14th, 2017, 7:53 pm
lowflyer2000's Avatar
Re: Hex ezcan on 2017 RT
Have a look at my earlier post "actual location of can bus on 2014 RT". I included some pictures of the location and what the unit (black box" looks like. I don't know about the 2017 but doubt it has changed locations.
If it isn't documented... it didn't happen.
lowflyer2000 is offline
post #3 of 14 Old May 15th, 2017, 11:28 am Thread Starter
Update - the Support department for ezcan finally got back to me. On the 2017 RT, there is no box that you unplug from. Instead there is a plug zip tied to the wire going to the rear lights with a white tag on it that says RDC. You simply plug the ezcan into this. It's very simple once you realize that their installation instructions do no apply to the 2017.
post #4 of 14 Old May 15th, 2017, 6:27 pm
LAF
LAF's Avatar
Good information for you lucky 17 owners!
I guess we can not assume anything on the 17 will be the same as 14,15,16's.
RDC moved, updated.
GS-911 needs an adapter and new software to run on it.
Interesting to see what other differences we will see.
Lee
15 R1200 RTLC San Marino Blue Metallic
10 Liquid Silver FJR1300 Sold
O7 Biarritz Blue Metallic LT Totaled 7/17/2010
ATGATT I am breathing proof.
BMW MOA #135959
LAF is offline
post #5 of 14 Old May 16th, 2017, 6:28 am
kellenbenz's Avatar
RDC moved, updated.
You do need the $30 adapter cable....but the GS911 does not yet work on the 2017 RT. It has different controllers and when you go to reset the service reminders, you get a fault stating "The controller is wrong for this motorcycle"
We will have to wait until they provide the updated software for these new controllers. I guess it has to do with the EU4 functions.
Ron
647,000 miles on touring motorcycles since 1990
IBA 45658 MOA167437 BMWLT #3
2000 LTC 90600 miles totaled (Purchased new)
2003 LTE 164188 miles Silver (Purchased with 1687 miles)
2008 R1200RT 172357 miles (Purchased with 16458 miles)
2017 R1200RT 582 miles (Purchased with 5 miles)
Total BMW miles 409,000
1982 GL1100 rode 84108 miles (bought with 12012 and sold at 96120)
1988 GL1500 rode 12067 miles (bought with 19893 and totaled at 31960)
1989 GL1500 rode 142208 miles (bought with 20302 and sold with 162510)
Goldwing miles 238,383
kellenbenz is offline
post #6 of 14 Old May 16th, 2017, 7:47 am
LAF
LAF's Avatar
Ron
Gottcha.
It is what I meant "by adapter and new software to run on it". I conveyed it wrong.
There seems to be a lot going on with the 17 other than the anti shudder, new shaft, new bearing and new shifting arms.
I guess what surprises me is the change of the diagnostic port. I can not think of any reason for them to do this to every dealer in the world that has to have the mother ship's computer.
I can not see anything that E4 Standard would dictate this?
And after I think about this does the OP even have TPS? That would explain no RDC unit
So maybe this is not a change but a non equipped issue
Lee
BMW MOA #135959
LAF is offline
post #7 of 14 Old May 16th, 2017, 8:38 am
lkraus's Avatar
I think EU4 (or EU5?) mandates a standard OBDII diagnostic connector??
Which might make it possible to use a standard auto OBDII tool in the bike.
lkraus is offline
post #8 of 14 Old May 16th, 2017, 3:54 pm
Sattwood 1633 - thanks for that update.
Have you tried it and does it work?
I assumed that the EZcan plugged 'in line between the wiring and the 'box' but if you are only plugging into 'one side', there will be a spare plug on the EZcan not connected to anything.
Just checking as I get my 17 RT in June and the EZcan is on the list!
Ta
sattwood1633 likes this.
Silver Rat is offline
post #9 of 14 Old May 16th, 2017, 5:36 pm
LAF
LAF's Avatar
Thank you for that it makes sense now.
That would be nice if in fact a OBDII works I have one for my car off my cell phone and it is pretty cool. I use Torque Pro I think for the App.
Of course I have a GS-911 so moot for me but may be good for others.
Lee
BMW MOA #135959
LAF is offline
post #10 of 14 Old May 16th, 2017, 5:44 pm
LAF
LAF's Avatar
Ta
We need Sattwood 1633 to let us know if he has TPS. I can see no reason why there is a cable marked RDC just laying there. It should be connected to a RDC unit or he does not have Tire Pressure System.
Or they have implemented another way to do TPS?
I guess either he or you will enlighten us as to what is going on.
Lee
BMW MOA #135959
LAF is offline
post #11 of 14 Old May 16th, 2017, 9:03 pm
lkraus's Avatar
I suspect that the RDC connector is a standard part of the main wiring harness, present on every wethead, regardless of whether it has a TPMS or not. Just as my '06 has connectors for an aux power outlet and (I think) an alarm system that I do not have. At least, the RTW parts fiche does not show a different main wiring harness or auxiliary cable for units with tire pressure monitors.
LAF likes this.
Larry
2006 R1200RT
lkraus is offline
post #12 of 14 Old May 18th, 2017, 10:55 pm Thread Starter
Sorry for the delay, I don't have TPS, perhaps that's why there is no box. The cable is simply zip tied very close to the rear light. Once I plugged the ezcan into it - all worked as designed.
post #13 of 14 Old May 19th, 2017, 8:35 am
LAF
LAF's Avatar
Cool thanks for letting us know.
I am sure it would be on the main harness, just could not figure put why it was just sitting there. Then I had a profound revelation that maybe your bike was not equipped with a RDC unit.
Not everyone buys a loaded up bike. Although the dealers try their hardest to make it happen
My SO's Father has a 16 with nothing on it and loves it to death. Of course he has been riding BMW for 60 years and is a retired Motorcycle Policeman so his taste in bikes is less is more. 81 and rides just about every day. His wife really kicks him out and tells him to take a ride!
Lee
BMW MOA #135959
LAF is offline
post #14 of 14 Old May 19th, 2017, 8:38 am
Enjoy that '17! I've had mine since February and I'm still in that phase that if I'm home and not riding it, I'm out in the garage looking at it.
LAF and TwoWheels like this.
bikerdudekc is offline
Human Verification
BMW's Tame the Dragon and Spring Training Camp 2017 jzeiler Rides, Rallies and Get-togethers 13 Apr 19th, 2017 6:31 pm
RTE Ride To Eat Northwest TN Saturday April 1st, 2017 See the Eagles Deerhead Rides, Rallies and Get-togethers 0 Mar 29th, 2017 12:23 pm
A second 2017 Las Vegas motorcycle auction! jeffdean RT Series 1 Feb 24th, 2017 9:39 pm
27th Georgia Mountain Rally May 5th to May 7th 2017 - All Welcome! R100RT_Mark Rides, Rallies and Get-togethers 0 Feb 2nd, 2017 9:27 pm
