Phone mount for 2007 R1200RT - BMW Luxury Touring Community
 1Likes
  • 1 Post By corrcullen
post #1 of 10 Old May 7th, 2017, 5:48 pm Thread Starter
Can anyone recommend a phone mount for my 2007 R1200RT?
I already have a RAM mount system for my sat nav fitted over the clutch reservoir.
I tried a similar set up for the phone over on the brake reservoir using the RAM x-grip, but brake fluid keeps leaking out, so I removed it and put back the original screws.
Is there anywhere else, other than the brake or clutch reservoirs, that I can put a phone mount or fit my x-grip to?
corrcullen is offline
post #2 of 10 Old May 7th, 2017, 6:03 pm Thread Starter
Re: Phone mount for 2007 R1200RT
After some further research, I'm thinking of using the migsel mount for the sat nav, and fitting the x-grip over the clutch reservoir.
BMW RT & GT - R1200RT - GPS mount - R1200RT - RAM type - all non LC - Migsel Bike Parts
Anyone try this mount?
Or maybe the phone & sat nav will fit on the migsel mount, if I buy an extra ball?
post #3 of 10 Old May 7th, 2017, 9:26 pm
Dann323's Avatar
I have the Migsel mount on my 07 RT
Best mount IMHO, it can hold up to 3 RAM balls
I have my GPS and my TPMS on it
Easy to install and solid
Daniel
If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
IBA # 56396
MOA # 171966
R1200RT 2007
Dann323 is offline
post #4 of 10 Old May 8th, 2017, 7:02 am
mtrevelino's Avatar
Depends on how high you want it mounted. I have a RAM mount in one of my fork bolts.
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #5 of 10 Old May 8th, 2017, 10:36 am Thread Starter
[quote=Dann323;1723305]I have the Migsel mount on my 07 RT
Just bought it, looks good, looking forward to getting it.
ClassicVelocity likes this.
post #6 of 10 Old May 8th, 2017, 2:45 pm
darammer's Avatar
I have the same mount connected to an Xmount and it works well. The only problem is there is a bunch of heat that comes up from the oil cooler and heats the phone. In the winter, it is not an issue, but in the summer my phone has shut down from getting too hot.
darammer is offline
post #7 of 10 Old May 8th, 2017, 5:14 pm Thread Starter
Unfortunately I wont have that problem in Ireland with our climate
post #8 of 10 Old May 9th, 2017, 11:39 am
I run the Migsel on my '06 RT. I like the Migsel and have three mount balls on it; I use two, one is GPS and the other a camera. I have my phone in a tank bag and simply unzip the bag to ID a caller. The phone will overheat in the map pocket on a tank bag. The phone can also overheat in extended direct sunlight exposure; this is more likely the case as opposed to oil cooler heat in my experience.
My only observation about the Migsel is that it gets a bit "bouncy" with the weight hanging off the mounts. My guess is the Wunderlich mount better handles the cantilever.
Joe's '06 RT is offline
post #9 of 10 Old May 9th, 2017, 1:20 pm
Page 22
Capt. Doron Grudo
Master Mariner ((Ret.)
91 K75
05 R1200GS
02 K1200LT
I rather be corrected than right.
doron is offline
post #10 of 10 Old May 17th, 2017, 1:17 pm
I have two of the handlebar bolt ram mounts similar to MTREVELINO. Using a combination of RAM extensions, I have been able to mount a variety of phone/GPS/camera options just using this set up. I have found that it is possible to mount things where they are positioned to be iin the line of sight looking forward as well.
www.classicvelocity.com
ClassicVelocity is offline
Human Verification
Cell phone mount for 2015 R1200RT Jawbone Accessories, Gadgets, and Gear 8 May 3rd, 2017 7:50 am
Phone Mount MHTOUR RT Series 22 Mar 28th, 2016 8:36 am
Phone mount?? Busajets Other Stuff 7 Jul 12th, 2010 9:33 am
3G iPhone and Mac 'geniuses' Randy Chit Chat 24 Aug 22nd, 2008 7:45 pm
Marsee Corona Mount Tank Bag on R1200RT? atps1234 RT Series 5 Aug 11th, 2008 4:04 pm
