How do I take the sidecases off ? - BMW Luxury Touring Community
 9Likes
  • 2 Post By BrzIRT
  • 1 Post By NoelCP
  • 3 Post By BamaBiker
  • 1 Post By NoelCP
  • 1 Post By PadG
  • 1 Post By WillH
post #1 of 22 Old Jan 4th, 2017, 10:09 pm Thread Starter
BrzIRT's Avatar
Question How do I take the sidecases off ?
2016 RT. The manual says to rotate the key to the release position. But it won't. It only goes between the dot and the "lock" position. I cannot get the handles to pop no matter what I try.
I have only tried doing this with the engine running. Could it be that sidecases can only come off with engine not running ?
Thanks folks
BrzIRT is offline
post #2 of 22 Old Jan 4th, 2017, 11:26 pm
Cat Herder
tvguy's Avatar
Re: How do I take the sidecases off ?
OK... are we being punked again... You need the key in the case to unlock it. Why would you have the bike running???
Tvguy
'16 R1200RT - "Golden Eye"
tvguy is offline
post #3 of 22 Old Jan 5th, 2017, 1:00 am Thread Starter
BrzIRT's Avatar
'cause I have keyless feature.
Key is in my pocket when I start the bike. Not riding as it is icy outside. Just start it once in a while.
As I am getting acquainted with the bike I tinker with it while the engine warms up to operating temperature.
The question is genuine.
BrzIRT is offline
post #4 of 22 Old Jan 5th, 2017, 1:18 am
McWideglide's Avatar
My key needs be turned firmly to release the handle for removal. I don't have a keyless ignition . Do you have a central locking. That may need unlocking first.
New bike, take it to your dealer and let them instruct you.
McWideglide is offline
post #5 of 22 Old Jan 5th, 2017, 6:39 am
LIRider's Avatar
Make sure you're turning the key in the right direction ... this happened to me once (or so I thought) only to find I was trying to turn the key the wrong way. You only need to turn it a little bit and the handle will simply pop up.
Current Rides:
2016 R1200RT - Platinum Bronze Metallic
Keyless Ride - Alarm - Shift Assist - Central Locking
1996 VF750C Magna - Pearl Shinning Yellow
V&H Classic II Pipes - Factory Pro Jet Kit
Race Tech Cartridge Emulators & Fork Springs
Progressive 440 Rear Shocks
LIRider is offline
post #6 of 22 Old Jan 5th, 2017, 9:40 am
jeffdean's Avatar
attached
Jeff Dean
Tucson, AZ -- formerly Madison, WI
BMW MOA #115; VBMWMO #2
'15 R1200RT, '15 R1200R, '67 R60/2 (x3),
'69 R60US, '55 R67/3, '49 R24
jeffdean is offline
post #7 of 22 Old Jan 5th, 2017, 9:41 am
ditto on the 'right direction' - I saw the sales person do it once. I tried a day later and could not for the life of me get that little handle to pop.... then I did.
I'm used to the cases on my R1200c (you opened them and released a lever inside to remove them) - these are going to take a little getting used to...
nhhandyman is offline
post #8 of 22 Old Jan 5th, 2017, 10:20 am Thread Starter
BrzIRT's Avatar
Originally Posted by jeffdean View Post
attached
Yeah, looked at that numerous times....will try with the bike not running...
BrzIRT is offline
post #9 of 22 Old Jan 5th, 2017, 1:40 pm
Why aint we riding's Avatar
Mines really simple. Turn the key to the release side (from memory it is also the locked side) and the handle pops up. never tried with the engine running but I cant see why that would make a difference. Mine can be unlocked and removed whether or not the auto-locks are engaged (auto-locks are automatically released when the bag is removed). Steve
Why aint we riding is offline
post #10 of 22 Old Jan 5th, 2017, 10:42 pm
garr2's Avatar
See my thread Steering lock intermittent fault which was about a weird electrical glitch that occurred on a bike where everything opens and shuts - as long as the computer says 'Yeeeess'. My intermittent fault (which happened over a 10 month period) never presented itself when the bike was in for a service. It sounds like yours is there all the time and so a trip the the workshop should see it fixed. I hope your nearest BMW workshop isn't a 250 km round trip like mine.
ian
garr2 is offline
post #11 of 22 Old Jan 5th, 2017, 11:57 pm
Cat Herder
tvguy's Avatar
The key is in the FOB... just push the small tiny silver button to release the key.
Make sure you unlock the central locking system by pushing the button with the arrow on it first. put the key in the lock and turn.
Tvguy
tvguy is offline
post #12 of 22 Old Jan 6th, 2017, 12:09 am Thread Starter
BrzIRT's Avatar
Went to the dealer. It turned out I was so scared of damaging anything that I did not apply enough twisting force to get the handle to pop up. Otherwise I was doing everything correctly.
Issue resolved.
Thanks for the help folks.
Geoff c and nhhandyman like this.
BrzIRT is offline
post #13 of 22 Old Jan 6th, 2017, 11:01 am
NoelCP's Avatar
Not a bad thing to be cautious--carry that caution with you when it's time to learn CORRECTLY how to remove and replace the side fairing panels to avoid the common mistake those 'who rush in' quickly discover.
Enjoy your new ride it's the best motorcycle ever built!
garr2 likes this.
2016 R1200RT - Dreamliner
2013 F800GT - Sold
1985 Kawasaki 1000 LTD - Sold
1968 Honda 350 - Sold
NoelCP is offline
post #14 of 22 Old Jan 6th, 2017, 3:28 pm
Now that you know how to take the case off, make sure the screws are tight on the "case stops" that are on the frame behind the cases.
LAF, garr2 and Why aint we riding like this.
Jack Goertz
'12 Triumph Bonneville
'15 BMW R1200RT
BamaBiker is offline
post #15 of 22 Old Jan 6th, 2017, 8:38 pm
NoelCP's Avatar
Some have discovered the screws back themselves out unless tightened and might as well use some thread lock while you're there.
Why aint we riding likes this.
2013 F800GT - Sold
NoelCP is offline
post #16 of 22 Old Jan 7th, 2017, 5:53 pm
RT2016's Avatar
Thanks folks
RT2016 is offline
post #17 of 22 Old Jan 9th, 2017, 6:45 am
2wheeljunkie's Avatar
I have another question for you. Why are you starting the bike once and awhile if you aren't riding it? From what i have believed over the years, and from what i have read on this forum numerous times, it is bad to start a bike for a short time then shut it down without going for a ride and warming the engine enough to burn out the pollutants. I have read on the forum numerous times that you can't get the bike hot enough to do this just by idling it. I could be wrong on this, maybe others could advise on this.
2wheeljunkie is offline
post #18 of 22 Old Jan 9th, 2017, 8:02 am
oldspice's Avatar
Originally Posted by 2wheeljunkie View Post
<snip> I have read on the forum numerous times that you can't get the bike hot enough to do this just by idling it. </sinp>
I think that is primarily for the air/oil-cooled bikes. I would think the water-cooled boxer would be a little safer idling. That said, I'm not sure what benefit there is to starting up the bike and not riding it - other than watching the needles/dash cycle through it's cool animation!
"Looks like I picked the wrong week to stop sniffing glue..."
2012 BMW R1200RT
1985 Ford Escort L (for Luxury) - Ol' Blue - gone, but not forgotten
MSF RiderCoach
BMW MOA 175432
BMW RA 41108
__________________
oldspice is offline
post #19 of 22 Old Jan 9th, 2017, 8:15 am
PadG's Avatar
The issue isn't related to idling temperature, but to the fact that if you start up for just a very short period and then shut down again, you are generating potentially corrosive gases in the engine (from burning rich mixture) that will mix with the moisture from the combustion to form acids which will accumulate in the engine oil, and that is NOT good! Taking the bike out for a ride after starting will flush out the corrosive gases, and allow the engine to run at the proper mixture, after warm-up, and the combustion will be more complete with less corrosive gases.
2wheeljunkie likes this.
Pad. Gajajiva
Solon, OH, USA
2007 R1200RT (Sold!)
Once Upon a Time........
1963 Norton Dominator 650 SS
1960 Triumph Thunderbird (6T)
1952 Triumph Thunderbird (6T)
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #20 of 22 Old Jan 9th, 2017, 10:10 am Thread Starter
BrzIRT's Avatar
The idea was to get it to operating temperature...run it like that for a while so that the battery can recharge...
After doing this 2 or 3 times it looks like I can leave the battery for up to three weeks and it will still have enough juice to start. The bike is kept at about 6C environment temperature.
BrzIRT is offline
post #21 of 22 Old Jan 9th, 2017, 11:07 am
You might want to consider investing in an inexpensive battery tender. Several models to choose from and many will work directly through the canbus plug already on the bike although most of us just wire a pigtail to the battery and use an SAE or similar type connector. This will extend the life of your battery compared to only cranking it up every few weeks.
Current Bike: 2014 R1200RT
Currently live in North Metro Atlanta
WillH is offline
post #22 of 22 Old Jan 9th, 2017, 11:47 am
NoelCP's Avatar
From the Rider Manual:
Danger of overheating
ATTENTION
Engine idling for a lengthy period while at a standstill. Overheating caused by insuffi- cient cooling. In extreme cases, the motorcycle could catch fire. Do not allow the engine to idle unnecessarily.
After starting, ride off immediately.
My understanding is our water boxers are only partially water cooled and still depend greatly on air cooling. That is corroborated on how quickly coolant temps increase when you come to a stop and have the engine idling when the cooling fan comes on, and that can happen in quite cool weather. I thought the message above from the manual was over concern, however my local dealer said nope it's not--they're heard of a bike catching fire from letting it idle in the garage! Didn't ask if it was a water boxer though. Moreover, BMW apparently formally advised against cooler guards on these machines due to concern over reducing cooling capacity, etc. Unlike your car which is likely fully water cooled, these guys aren't the same.
Plus, on a newer battery, how long can you leave the bike w/o running it? Seems like a month+ is no big deal on a newer battery, but I really don't know. My 3y/o F800GT sat for 5 weeks while we were away and voila, started right up. 3y/o battery. Battery tender if you're stuck for winter I guess is a good idea.
2013 F800GT - Sold
NoelCP is offline
Human Verification
Do Modular Helmets Fit In Sidecases? want2tour K1200LT 28 Aug 25th, 2015 8:03 pm
Anyone familiar with R1150GS sidecases? rdwalker Bike Talk 5 Sep 20th, 2007 1:43 pm
