Trouble After Adjusting Shifter on 2016 RT? - BMW Luxury Touring Community
 9Likes
  • 1 Post By lkraus
  • 1 Post By LIRider
  • 1 Post By LIRider
  • 1 Post By LIRider
  • 1 Post By PadG
  • 2 Post By LIRider
  • 1 Post By jeffdean
  • 1 Post By LIRider
post #1 of 21 Old Mar 12th, 2016, 1:46 pm Thread Starter
LIRider's Avatar
I installed a set of Suburban-Machinery lowering pegs earlier in the week and decided to see what sort of adjustments could be made on the controls. I understand that the brake lever isn't adjustable but actually found that you can get about a half inch of movement if you remove the brake lever, loosen the lock nut and turn the collar up a few turns (about as far as you can go). That got the brake down far enough as to feel comfortable for me.
So, now I go onto what's supposed to be the easy side to adjust the shifter and indeed it was easy to adjust. Loosen the two lock nuts on either side of the turnbuckle and spin the entire rod one way to raise and the other way to lower the shift peg. I drop the shifter about an inch, tighten everything up and then hop on to go for a spin but I can't get the bike to go into first gear. Okay, so back up on the center stand to fiddle some more with the adjustment ... raised the shifter a little and tried again ... better but still difficult to get into first (or downshift at all). Raise the shifter even further and things are once again back to normal. So my question is has anyone experienced anything similar when adjusting the shifter?
Current Rides:
2016 R1200RT - Platinum Bronze Metallic
Keyless Ride - Alarm - Shift Assist - Central Locking
1996 VF750C Magna - Pearl Shinning Yellow
V&H Classic II Pipes - Factory Pro Jet Kit
Race Tech Cartridge Emulators & Fork Springs
Progressive 440 Rear Shocks
LIRider is offline
post #2 of 21 Old Mar 12th, 2016, 2:56 pm
lkraus's Avatar
Re: Trouble After Adjusting Shifter on 2016 RT?
Sounds like the lever movement is restricted by the lever or linkage hitting something. Will the design allow you to change the position of the lever on the selector shaft where it exits the transmission? That is, disengage the clip holding the ball joint so you can disconnect the linkage, remove the screw clamping the lever to the gear selector shaft, pull the lever off and then reinstall it but rotated by a spline or two. The picture on the repair DVD is not clear, it might not be possible to fit the lever in more than one position.
Geoff c likes this.
Larry
2006 R1200RT
lkraus is offline
post #3 of 21 Old Mar 12th, 2016, 3:01 pm
tokig's Avatar
I am looking for lowered pegs, raised handle bars and taller windscreens. Please keep us posted on this foot peg.
And wondering if $500+ is needed to lower brake and shift levers as well!
I see a $200 brake pedal at Ilium.
2016 R1200RTW & old British bikes
tokig is offline
post #4 of 21 Old Mar 12th, 2016, 3:19 pm Thread Starter
LIRider's Avatar
I'll take a look at that for sure. The funny thing is that Suburban Machinery now sells a longer turnbuckle for the wethead RT so I'm not sure why that would work at all if I'm hitting some restriction with the stock turnbuckle in place.
Geoff c likes this.
Current Rides:
LIRider is offline
post #5 of 21 Old Mar 12th, 2016, 3:21 pm Thread Starter
LIRider's Avatar
I'm pretty sure that many here have gone this route without issue ... which makes me wonder what it is I'm doing wrong
Current Rides:
LIRider is offline
post #6 of 21 Old Mar 12th, 2016, 3:30 pm
tokig's Avatar
This maybe the shift linkage IPB.
tokig is offline
post #7 of 21 Old Mar 12th, 2016, 3:36 pm Thread Starter
LIRider's Avatar
Maybe it's the shift assist system that's somehow involved ... I'll have to look more closely at that too.
Geoff c likes this.
Current Rides:
LIRider is offline
post #8 of 21 Old Mar 12th, 2016, 4:11 pm
Bighopper's Avatar
I adjusted a friends '15 RT, I took the rod off & adjusted the 2 end joint out as far as i thought was safe with enough engagement into the joints the tightened the nuts & all went good.
But I can't remember if he had shift assist.
Either way i don't see shift assist being an issue as you are moving the gear shift lever (#1 in a post up further) up or down not the gear lever into the gearbox.
BIGHOPPER (Phil)
BGB 602
2006 K1200LT Grey
1973 Norton Interstate
1965 Atlas 750
Bighopper is offline
post #9 of 21 Old Mar 13th, 2016, 7:00 am Thread Starter
LIRider's Avatar
Okay, think I might know what the problem may be ... woke up last night to use the facilities and on the way back to bed, remembered that I never checked for clearance with the side stand up (old habit of leaving the side stand down when using the aftermarket center stand on my Magna). I've got an Altrider side stand foot enlarger on my RT and I think it may be interfering the shift mechanism when it's extended further back as it would be when you lower the shift peg. I'll check it out after breakfast but this at least makes sense.
Edit: Confirmed! A case of farkle interference ... AltRider foot interferes with shift mechanism when the shift peg is lowered. Note that this is the same foot enlarger that BMW now sells. My options are to loose this foot, replace with another that doesn't interfere or mod this foot by relocating the one screw and grinding/cutting the foot base.
Guess I do my best thinking at night (when I should be sleeping) or perhaps the rest just cleared my mind enough to realize I should have checked for clearance issues in the linkage. In any event, I'm glad that's all there was to it.
ID:	100410   Click image for larger version
Geoff c likes this.
Current Rides:
LIRider is offline
post #10 of 21 Old Mar 13th, 2016, 9:10 am
PadG's Avatar
I think that you have got it! Illium foot-enlarger had to be modified from their original release because it will interfere with the shift mechanism, and so I suspect that it is the same with yours!
Geoff c likes this.
Pad. Gajajiva
Solon, OH, USA
2007 R1200RT (Sold!)
Once Upon a Time........
1963 Norton Dominator 650 SS
1960 Triumph Thunderbird (6T)
1952 Triumph Thunderbird (6T)
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #11 of 21 Old Mar 13th, 2016, 9:16 am Thread Starter
LIRider's Avatar
You must have posted as I was updating my last post. That was exactly the problem and I believe it was your original post about the issue you had with the first iteration of the Ilium foot enlarger that I remembered last night and got me to thinking it might be my issue. Thanks Pad!
PadG and Geoff c like this.
Current Rides:
LIRider is offline
post #12 of 21 Old Mar 13th, 2016, 10:26 am
jeffdean's Avatar
I have the Ilium foot peg lowering kit on my 15RT and have had no trouble with lowering and using the shift lever. I use the Wunderlich sidestand foot enlarger.
Geoff c likes this.
Jeff Dean
Tucson, AZ -- formerly Madison, WI
BMW MOA #115; VBMWMO #2
'15 and '17 R1200RTs, '69 R60US,
'67 R60/2 (x3), '55 R67/3, '49 R24
jeffdean is online now
post #13 of 21 Old Mar 13th, 2016, 11:44 am
Bighopper's Avatar
I guess the first question from now on for the newer RT's is 'What Farkels Did You Install'
BIGHOPPER (Phil)
BGB 602
2006 K1200LT Grey
1965 Atlas 750
post #14 of 21 Old Mar 13th, 2016, 4:07 pm
I put Wunderlich vario peg lowering on my 2014 and changed the shifter, it did take a while to get the adjustment right, and if I recall the downshift into first was a problem until I fiddled with the linkage.
I have shift assist as well.
scrabble is offline
post #15 of 21 Old Mar 11th, 2017, 4:09 pm
Sorry to resurrect an old post but I was looking at the suburban machinery STL1-lower shifter rod. The tech at BMW suggested to be careful as the extra throw might impact (force) the gear shift pro mechanism..so I assume folks have had some success "walking" their shooter rod out a little.. has anyone ordered the stl1 and have had no issues so far? Or is it not needed as the shift lever is adjustable enough to support the new foot peg position..
Ihbond2 is offline
post #16 of 21 Old Mar 13th, 2017, 6:24 am Thread Starter
LIRider's Avatar
I found I could adjust mine to a comfortable position without the need of any sort of extension. Try it and see what you find. I've had no issue with shift assist pro after lowering the shifter. My only issue was with the foot stand enlarger, which interfered with the shift mechanism. I ground down the foot and relocated one of the securing screws. No problems ever since.
Geoff c likes this.
Current Rides:
LIRider is offline
post #17 of 21 Old Mar 13th, 2017, 9:59 am
LIRder: Will do!....
I like taking the cheap route first if that is an option, so i was plan on adjusting the shifter as you mentioned above....
HOwever it struck me odd about the suburban machinery rod extender and what the tech said..and before I went don't that route, i thought i would try to solicit some feed back likes yours and others as well...
Ihbond2 is offline
post #18 of 21 Old Mar 15th, 2017, 5:06 am
Geoff c's Avatar
When you see the photo and compare them I am sure your correct , funny how your mind must check thing while your sleeping . I know when i have done something and it did not go as planed a rest and come back a few mins or the next day and you seem to think more clearly. I am happy you have that sorted.
Geoff c is offline
post #19 of 21 Old Mar 19th, 2017, 12:00 am
What's interesting is the repair manual say distance between ball ends should be 123.5 mm +/- .5 mm...I'm about 130mm..they must have put these tolerances for some reason?
Ihbond2 is offline
post #20 of 21 Old Mar 22nd, 2017, 8:00 am
I had the same issue. Embarrassingly, I realized that the rear portion of the shift arm was hitting the kickstand foot pad I had added. A couple of twists on the assembly and it returned to original functionality.
Pontatoc1 is offline
post #21 of 21 Old Mar 23rd, 2017, 10:08 pm
Nardowell's Avatar
Grinding my foot farkel down and removing a screw worked for me.
Nardowell is offline
Human Verification
2016 Registration Now Open docedkin Curve Cowboy Reunion 23 Jan 11th, 2016 6:02 pm
Same old shifter lingage trouble bruce13p K1200LT 8 Jul 29th, 2007 5:45 pm
Reattaching Shifter Linkage Reid K1200LT 7 Jul 28th, 2007 8:38 pm
