Garmin 660 or BMW Nav V. - BMW Luxury Touring Community
 15Likes
  • 1 Post By bandytales
  • 1 Post By gerhard
  • 1 Post By rapz
  • 1 Post By Hammam
  • 1 Post By blueknightga6
  • 1 Post By jimjim
  • 1 Post By jimjim
  • 3 Post By Yammer
  • 2 Post By bandytales
  • 1 Post By Hammam
  • 1 Post By Yammer
  • 1 Post By REWDOC
post #1 of 27 Old Oct 23rd, 2014, 3:50 am Thread Starter
I've just bought RT water-cooled! Do I buy the Garmin 660 or BMW Navigator V!!!
I.Willis is offline
post #2 of 27 Old Oct 23rd, 2014, 6:10 am
bandytales's Avatar
Re: Garmin 660 or BMW Nav V.
Well, not the 660.
So you have bought a wethead without the satnav? so it has not got the built in unit? Curious decision if you are a SatNav user.
If your bike is secondhand and has the dashboard to take the BMW SatNav, I'd get that, if not I would steer you towards the Garmin 590LM. Very similar to the Nav 5, but a really good unit.
The 590 outperforms the 660 in real areas of user friendliness and features.
bandytales is offline
post #3 of 27 Old Oct 23rd, 2014, 6:28 am Thread Starter
Yes the bike is secondhand! I thought the BMW V was a rebadged 660 but the only advantage with BMW V 5 could be controlled from the muli control wheel!
Thanks for your reply.
I.Willis is offline
post #4 of 27 Old Oct 23rd, 2014, 6:56 am
gerhard's Avatar
I think the Nav V is a repackaged Zumo 590, the Nav IV was the Zumo 660.
Gerhard
gerhard is offline
post #5 of 27 Old Oct 23rd, 2014, 7:07 am
bandytales's Avatar
So can I clarify that this bike has the modified dashboard that has the built in SatNav holder?
If so I would go with the Nav 5 as it integrates with the thumb wheel for readback of some of the bike data.
If it is a model that does not have the raised dashboard I would go with the Garmin Zumo 590LM. As Gerhard says, the 590LM is the more equivelent of the Nav 5. However it does not have the software to accept the data from the bike, so it would be a standalone unit...all be it a very good one.
post #6 of 27 Old Oct 23rd, 2014, 7:26 am Thread Starter
Thanks Bandytales. Yes it the bike is Satnav prepared! I was not sure if the garmin would go straight into the satnav hole and was the extra expense of the BMW Nav worth it?
I.Willis is offline
post #7 of 27 Old Oct 23rd, 2014, 9:10 am
bandytales's Avatar
Pretty sure the casing is different so no, it won't go in. However, I will wait for other Wethead owners to chime in, because some of them have 2 bikes, and may be running a 590LM on the second bike.
I.Willis likes this.
post #8 of 27 Old Oct 23rd, 2014, 9:21 am
gerhard's Avatar
The screen on the Nav V is larger than the NavIV or 660 but I believe the outside dimensions are the same but the 590 is completely different case. I am pretty sure that I saw a 660 on the factory mount of a GS so why shouldn't it work on the RT. There must be folks here that have a '14 RT and Garmin 660 that can give the definitive answer.
Gerhard
gerhard is offline
post #9 of 27 Old Oct 23rd, 2014, 9:41 am
rapz's Avatar
I have the BMW Nav V and the cradle has those hard buttons on the left side so should your cradle. If not, then it's for the 660 or other non-BMW Nav unit imho. I don't have the radio/thumb wheel setup, but if I did, I would go with whatever integrates with that option. I think it's much easier to thumb through the GPS than to push either the hard buttons or screen commands meaning that your hand is off the handle bars.
Website:
2013 BMW 90th Anniversary R1200RT
1979 BMW R100RT
2008 Harley Davidson 105th Anniversary Ultra Classic
IBA No. 58411
rapz is offline
post #10 of 27 Old Oct 23rd, 2014, 1:25 pm
Hammam's Avatar
Gerhard
I have a 14 RT, and the Zumo 660 fits perfectly. It is not wheel-controlled of course.
Hammam is offline
post #11 of 27 Old Oct 23rd, 2014, 1:58 pm
blueknightga6's Avatar
Here's something interesting I found out about the NAV V I'm waiting for to arrive after purchasing my 2014 R1200RT. I called the dealer about something else and asked about an ETA on the NAV unit. He told me that it was ordered to go along with my VIN, even thought it was the free incentive.
Chris Ehlbeck
blueknightga6 is offline
post #12 of 27 Old Oct 23rd, 2014, 3:16 pm Thread Starter
Hamman Thanks for your reply. Would it be possible for you to post or send me a picture of the 660 on your bike. No hurry! Thanks again.
I.Willis is offline
post #13 of 27 Old Oct 23rd, 2014, 5:35 pm
jimjim's Avatar
Here's the 660
The Nav V
jimjim is offline
post #14 of 27 Old Oct 23rd, 2014, 6:12 pm Thread Starter
Thanks JimJim Any views? I'd appreciate!
I.Willis is offline
post #15 of 27 Old Oct 23rd, 2014, 8:58 pm
jimjim's Avatar
No brainer, buy the Nav V. It has a slightly larger screen and can be operated with the thumb wheel and setup for special functions.
'14 R1200RT
'12 Tiger 800
jimjim is offline
post #16 of 27 Old Oct 23rd, 2014, 9:05 pm
Just my two bits. I have both 660 and Nav V and have used them for as long as they have been out. The Nav V is far superior on several fronts and it integrates to the bike (go to the website to see what is different). The 660 is at the end of its life and not getting much support from Garmin these days. The new 590 is a pretty powerful one too but the integration of the Nav V wins in my opinion. The only thing they screwed up on is that it can not be locked into place and for some strange reason a Nav V installed in a GS gets much more data from the bike than when it is plugged into the RT.....bit jealous about that things like how many shifts what gears yada yada....
tvguy, misterO and I.Willis like this.
Yammer is offline
post #17 of 27 Old Oct 24th, 2014, 7:14 am
bandytales's Avatar
There you go. Both jimjim AND Yammer have confirmed that the Nav 5 which integrate are worth it.
Job done
Yammer and I.Willis like this.
post #18 of 27 Old Oct 24th, 2014, 10:44 am
Hammam's Avatar
Two things I don't like about the 660 on the RT:
- The way the cradle is connected to the Canbus, the GPS goes on automatically when I switch the ignition on. It has to (I couldn't do it myself otherwise), but I can't turn it off because the upper button is now under the shield, and I have no control with the thumb wheel. And I don't like to have that GPS on when I don't need it. Not terrible, but irritating.
- Worse, the angle of the cradle is such that the screen of the GPS becomes invisible under some lighting. On my GS, I had a sun shield or visor that I stuck with Velco around the unit, but now I can't do that anymore. By the way, I'd appreciate any tip to solve that problem. Thank you.
Hammam is offline
post #19 of 27 Old Oct 24th, 2014, 1:29 pm
Alfred02's Avatar
That is one of the big advantages of the Nav5 compared to the 660. The screen brightness/display is far better in bright light on the Nav5 then it is on the 660.
That alone is already enough to choose the Nav5.
As I wrote my 2005RT to the dealer with the 660 mounted and operating, then left with the 2014RT and the Nav5 mounted and operating, the improved display readability was immediately apparent. A big difference
2014 R1200RT-SE/LC Ebony Metallic
Alfred02 is offline
post #20 of 27 Old Oct 24th, 2014, 4:01 pm Thread Starter
Thanks Guys for the advise! I'm picking up a Nav V tomorrow morning from my local BM dealer.
I.Willis is offline
post #21 of 27 Old Oct 24th, 2014, 9:45 pm
Good luck, if you go online you can pick up some cheap screen protectors to and it will definitely help keep the screen looking tip top.
Yammer is offline
post #22 of 27 Old Oct 24th, 2014, 9:52 pm
REWDOC's Avatar
Exclamation Re: Garmin 660 or BMW Nav V.
If you just bought it new, you should get a Nav 5 free with the bike as BMW is having a special deal until the end of the year. I just got mine with the bike at no charge.
Dick Wood
Previous 1995 HD FXDL
IBA #7393
REWDOC is offline
post #23 of 27 Old Oct 24th, 2014, 10:11 pm
True. I bought a new 2014 R1200RT last week and I'm waiting for delivery of my NAV V.
Chris Ehlbeck
post #24 of 27 Old Jan 16th, 2016, 11:54 am
OKUIII's Avatar
I used to think that the BMW labeled devices were all hyped-up junk...but after buying the Garmin 590LM and having nothing but trouble seeing the screen i sold it when I got the new 2016 GS.......I got the Nav V on the GS and what a difference. I can see the screen in all lighting conditions...THis is the first BMW add-on I have ever bought that is really a significant advancement over after market...
The 590LM, although design for Motorcycles is worthless in some daytime conditions...It did have some really great function when traveling on long trips with gas stops and other waypoints, but it does not compare to the Nav V screen.....I am really a happy camper now..Glad I got it
O. K. Upchurch III
Irvine, California
2016 R1200gs
2000 K1200LT (Best Bike #1)
1997 R1100RT (Best Bike #2)
1995 K1100LT
1990 K75RT
OKUIII is offline
post #25 of 27 Old Jan 16th, 2016, 9:59 pm
picker's Avatar
The 590 has a transflective Reflective vs. Transflective Displays display so the more direct light the better! (get it out of the shade on your RTLC). It also has a backlight for these overcast days, but its not as bright as my old 660.
picker is offline
post #26 of 27 Old Jan 19th, 2016, 11:47 am
picker's Avatar
The 590 has a Transflective screen so the more sunlight the better! (get it out of the shade).
picker is offline
post #27 of 27 Old Jun 24th, 2016, 9:51 am
I can confirm the Zumo 660 is form and plug compatible with the GPS mount on a '16 wethead RT. I've road tested it.
What's not clear to me is whether the 590-series is form and plug compatible. Of course the added four button mount is excluded from determining compatibility.
Agreed that the 660 does not respond to the wheel. IMNSHO no loss - I really, really, really dislike the wheel as much as I dislike the I-Control and its siblings in cars. Both the wheel and single-knob control take my eyes off the road for far too long. Not Good
RBEmerson is offline
Human Verification
BMW Recalls 18 Models in Canada for Potential Fuel Leaks meese K1200/1300GT (The Next Generation) 5 Jan 21st, 2014 9:29 pm
BMW mirror mount for a Garmin GPS - hard wire? 01K12LTC K1200LT 18 Aug 7th, 2013 2:29 pm
Registering a post 2004 LT in France mcousin Europe 7 Aug 15th, 2011 4:56 am
Replacement BMW Nav II from Garmin Map Detail not Unlocking... BlackBMW GPS 11 May 25th, 2010 3:01 pm
Motorrad BMW/ Garmin Nav 2 BruceFPrichard Australia, New Zealand, and AsiaPac 0 Jul 16th, 2007 1:56 am
