K1200LT 06 alarm/imobilizer - BMW Luxury Touring Community
 3Likes
  • 1 Post By simoncharles
  • 2 Post By Andrew Stevens
post #1 of 32 Old Jun 23rd, 2013, 7:50 am Thread Starter
There has to be a way to get around this imobilizer. Just stopped recognizing the fobs. The only way I can start the bike is the key turns matching the code on the card. I cannot get the unit to read or recognize the fobs. I have done the steps to sync and register, nothing is working. I want to deactivate this system. Please help.
mmc2013 is offline
post #2 of 32 Old Jun 23rd, 2013, 9:30 am
Re: K1200LT 06 alarm/imobilizer
You can bypass the entire alarm but you will loose the central locking feature.
Remove the top case and the panel underneath it. Top case locked you say? Ok insert key and turn 45 degrees, open top case.
Find the alarm and undo all the connectors. There are three – 2 pin, one -3 pin, one- 4 pin and one - 12 pin.
To get the bike running again you need to jumper the following pins on the 12 pin connector. Pin 3 (black/white/yellow) to pin 11 (black/yellow); this is the starter button signal to the starter relay. Then jumper pin 10 (green/violet, switched power) to pin pin 6 (blue/violet, engine electronics relay). Now the bike will start and run normally.
2009 K1300GT
2005 Ocean Blue Blue Wizard
CCR 06 Braselton CCR 07 Osage Beach CCR 08 Midway
CCR 09 Rapid City CCR 10 Killington, VT,CCR 11 Boise, CCR 12 Duluth
CCR 2013 Bend, CCR 2014 Backyard! CCR 2015 Couer d'Alene
post #3 of 32 Old Jun 23rd, 2013, 10:48 am Thread Starter
Thanks for the help on this. I will get into this today. Have you ever seen this failure before? I am thinking the alarm system has to have a RF receiver in it that has gone bad.
Mark
mmc2013 is offline
post #4 of 32 Old Jun 23rd, 2013, 12:38 pm
I have 2006 K1200lt, love it, but tired of having to get the fob out and unlock the bike every time I shut it off like at a gas pump. How do I keep the anti theft, but only use when I turn it on. I don't want it to automatically engage EVERY time. It still responds to the fob but tired of using it all the time!!!
Like-the-wind is offline
post #5 of 32 Old Jun 23rd, 2013, 12:59 pm Thread Starter
You did it, man. I love you As it was I had no central locking anyway as the module will not respond to fobs. It just happened. I parked the bike and the next time I tried to start it the module was dead. I am assuming the alarm/imobilizer is made up of these two parts: the small plastic Italian-made module with a 4-pin cable coming out, and the BMW unit with the alarm horn. The one of these units that reads the RF codes has to be bad. If I can determine which one I will replace, as I like things to work as they should.
The two jumpers have done it and I can ride, many many thanks for you help. I wish the dealer (many many miles away) could have been this helpful.
Mark
mmc2013 is offline
post #6 of 32 Old Jun 23rd, 2013, 1:07 pm Thread Starter
If your bike is reading the fobs, you can go into programming and deactivate auto-arm. You should have an alarm supplement booklet with your owner's guide. If so look for the program instructions using key turn on, etc. Have your security code from the card handy....make sure you check your card's code. My card was in a sealed envelope, with additional code stickers on the envelope that did not match the card. You must peel off the foil covering the code. More secure than nuclear trigger locker on US SSN.
mmc2013 is offline
post #7 of 32 Old Jun 23rd, 2013, 5:43 pm Thread Starter
To: John
I think we need one more jumper: turn signals/flasher does not work with 12-pin connector unplugged. When I remover my two jumpers and plug back in, turn signals work.
Any thoughts?
mmc2013 is offline
post #8 of 32 Old Jun 24th, 2013, 6:59 pm
I thought so and used to say jump the Pin 2 Green wire to the pin 10 and pin 6 as it is a switched power lead to the flasher but that kept them on all the time(or at least some one had that issue). Give it a try and see what happens. Then let me know and I'll fix my documentation.
2009 K1300GT
post #9 of 32 Old Oct 23rd, 2016, 10:16 pm
Any idea if this will work for a '03?
In a real bind here
frhekö is offline
post #10 of 32 Old Oct 24th, 2016, 3:22 pm
Does the little red light on the fob flash on and off even if the fobs battery is flat ?.
My bike has been off the road for several months and due to the maintainer not working, I have had to install a new battery as it was a goner.
Everything works ( cases can be opened and closed, screen goes up and down, central stand goes up and down ) except that the motor turns over but won´t start, therefore I am wondering if it has something to do with the alarm.
If not, any suggestions would be appreciated, even asking me if there is fuel in the tank ( yes, but not much ).
simoncharles is offline
post #11 of 32 Old Oct 24th, 2016, 7:11 pm
If the light is flashing on the FOB when you press a button the batteries are still good, but may be on the way out. If you can lock and unlock the side cases with the FOB then the alarm is responding. An unlock press would also disable the immobilizer but it has to be done each time you cycle the key.
So I would suspect a fuel related issue. Check for pressure as a hose may have burst or come off in the tank.
2009 K1300GT
post #12 of 32 Old Oct 24th, 2016, 7:14 pm
In a real bind here
Yes this will work on an 03:
2009 K1300GT
post #13 of 32 Old Oct 25th, 2016, 8:18 am
Thanks for your reply.
I did not make myself clear when I said the cases can be opened and closed. They can by hand, but not when using the alarm, which doesnt make a sound.
The fuse is also shorting ( no horn ), so it looks like it´s the dreaded alarm problem, as as you said a while back, the bike needs to be used and not parked.
So.........I will remove the top box and isolate the alarm as you have previously suggested.
Having a working alarm makes me feel that bit more relaxed, so if it is kaput, I will most probably install a new one.
Will keep you updated.
post #14 of 32 Old Oct 26th, 2016, 1:34 am
Super. thanks! Fortunate for me, the person I bought it from contacted the original owner who still had the spare key and the spare transmitter in the original packaging!!! No need to jig the electronics. I figured the battery in the transmitter would be stone cold after 13 years, but it worked like new.
frhekö is offline
post #15 of 32 Old Oct 27th, 2016, 4:22 pm
John,
Are you saying that apart from undoing the 12 pin connector, I must also undo the other 5, in other words the 3 x 2 pins ones, the 1 x 3 pin one and the 1 x 4 pin one ?.
I do hope so as I only undid the 12 pin connector and the 15 amp fuse is still blowing, which has me really worried.
No computer where the bike is so I couldn´t check until I got home.
One thing that baffles me is that the turn signal lights don´t work when the 12 pin is disconnected but do when connected.
Do you think that they will work after I have jumped the pins ?
Which fuse are they on ?.
Whilst they were flashing I removed every fuse one by one in both boxes and they still kept on working.
Simon
post #16 of 32 Old Oct 27th, 2016, 4:29 pm
Another question.
How do you guys make sure the 2 jump wires stay in place ?.
As far as I can see there are no small screws to loosen to allow you to safely and securely attach the wires to the 12 pin connector.
Thanks in advance for any tips on how to do this.
Simon
post #17 of 32 Old Oct 27th, 2016, 4:36 pm
John,
Did Mark get back to you about this ?.
Simon
post #18 of 32 Old Oct 27th, 2016, 8:23 pm
Pin 2 is power from the alarm to the flasher in the 05 and up bikes and must jumpered to pins 6 and 10. On the pre 05 if you jumper pin 2 the lights are on all the time.
To stop the fuse from blowing just disconnect the three pin (green, red/white and brown wires). But the bike will not start unless you unplug the 12 pin and jumper the pins as stated.
2009 K1300GT
post #19 of 32 Old Oct 28th, 2016, 2:23 am
Thanks.
Mine is a 05
Will let you know how it goes.
post #20 of 32 Old Oct 31st, 2016, 1:40 pm
OK, here is my latest news about disengaging the alarm and getting the bikes electrical system working again.
John, thanks, you are right about it being sufficient to unplug the the 3 pin connector to stop the 15 amp fuse blowing.
Have you any idea what causes this ? Is it because the alarm has short circuited or only the receiver ?.
Why does this happen after only not being used for several months, or is it down to the bikes battery going flat ?.
After doing this ( and changing the fuse ) the horn and brake lights start working.
BUT the engine doesn´t turn over nor do the turn signals work.
To get the engine turning over you have to jumper pin 3 to 11 and presumably to get the engine electronics back, jumper pin 6 to 10.
I say presumably because the engine still won´t start, although it does turn over, which I am hoping is due to a stuck or broken fuel pump.
As soon as I can I am going to dismount the left hand side panels and see if there is any fuel pressure at the injectors.
If not, I will have to remove the pump and go from there.
In regards to the turn signals which still do not work after doing the two previous jumpers, you have to jumper pin 2 to 10 and they then start flashing off and on as they were designed to do.
As I mentioned previously my LT is the newer model.
Hope this helps.
Hilton likes this.
post #21 of 32 Old Oct 31st, 2016, 9:30 pm
There are internal batteries in side the alarm unit and they are not serviceable. When they go bad it causes the short that blows the fuse. The only fix is to replace the alarm unit.
ID:	118281   Click image for larger version
2009 K1300GT
post #22 of 32 Old Nov 1st, 2016, 3:53 am
Thanks John !
post #23 of 32 Old Nov 1st, 2016, 8:57 pm
The neat part whether you replace the alarm or not is to use the 12 pin plug off the alarm. I had a bad unit sent to me for fun ( where the pictures came from) and I used the 12 pin connector from it to do the jumping of the wires and now I keep it in the side case. If I ever have a failure of the alarm on the road all I have to do is unplug the alarm and plugin the pre-jumpered connector and I am back in business.
2009 K1300GT
post #24 of 32 Old Nov 2nd, 2016, 3:53 am
Thanks for that.
I suppose you have fead the line back to somewhere under the rear seat so you won´t have to remove the topcase.
Yes, I am planning on replacing the alarm, not so much for anti-theft benefits but more for it´s central locking facility.
As I understand it, I will "only" have to replace part # 65757678934 (maybe you could confirm) of which I have seen a few on the net.
My only worry about these is that they won´t come with the code that is needed to programme the fobs, as I am presuming that I will be able to use the two original ones that came with the bikes original alarm installation.
Or am I presuming too much : ) ?
post #25 of 32 Old Nov 6th, 2016, 5:22 am
Could anyone tell me from what year and until when this alarm ( # 63945210) was used by BMW ?.
It´s not the same as mine (2005) but here´s a tutorial on how to change the batteries on it.
On mine you can´t.
https://drive.google.com/file/d/0B7q...yYjFkNDE4/view
post #26 of 32 Old Nov 6th, 2016, 2:14 pm
That looks like the alarm module that would go to a K1300GT or other CanBus BMWs.
And yes just the PN 65757678934 is all that needs replacement. I have a friend in the same situation and that is what he bought. He then sent me the old one to tear into.
2009 K1300GT
post #27 of 32 Old Nov 6th, 2016, 3:28 pm
Thanks John.,
The guy who posted the tutorial on a Spanish BMW site ( BMW MOTOS - Todo sobre el mundo de las motos BMW ) says it is from an RT, but that LT´s also had them installed.
Did your friend buy a new one or a used one ?
post #28 of 32 Old Feb 16th, 2017, 10:12 am
K1200LT 2005 (new model)
I am just about to order a new alarm module ( 65757678934 ) as I can´t find a suitable used one.
Does anyone know if my original fobs will work with the new module if they are programmed using the new code that will come with the module ?.
Thanks in advance.
post #29 of 32 Old Feb 17th, 2017, 6:43 pm
Yes they will. I had a friend that did the same thing on his 05 and he had no issues with his old FOBs working with the new alarm.
2009 K1300GT
post #30 of 32 Old Feb 17th, 2017, 7:18 pm
Thanks John.
I had imagined that that was the case, but wanted to confirm before ordering the module.
Simon
post #31 of 32 Old Apr 23rd, 2017, 6:37 pm
I have an 2006 K1200LT that had same problem. I disconnected 12pin connector and fuse still kept blowing. I found all the wires melted together and removed the alarm completely. I then wired like the described above. My bike started.
ID:	125649   Click image for larger version
Patric and simoncharles like this.
Andrew Stevens is offline
post #32 of 32 Old Apr 25th, 2017, 12:59 pm
Regarding my comment about the bike not starting in post #20, it was due to the fuel pump not working and not due to the wire jumpering, which is good as how I described it after following John´s instructions.
Human Verification
looking to buy k1200lt, LA, CA powerman5kw South West 32 May 29th, 2017 10:56 pm
How low to go to sale 03 LT? shotgun K1200LT 37 Apr 6th, 2017 4:50 pm
Follow-up. We're inheriting my father-in-law's K1200LT! Humbucker K1200LT 18 Sep 15th, 2011 11:41 am
Some references for K1200LT Riders outside Europe k1200lt_rider Europe 9 Aug 31st, 2008 6:38 am
