Bosch 72161 oil filter WARNING! - BMW Luxury Touring Community
 7Likes
  • 1 Post By Fountain
  • 2 Post By DanDiver
  • 1 Post By amindtat
  • 2 Post By Voyager
  • 1 Post By JWA
post #1 of 29 Old Feb 19th, 2008, 8:48 am Thread Starter
kellenbenz's Avatar
Some of you may know that I have recommended buying these filters from www.rockauto.com . While changing my oil yesterday I noticed that the filters that I got through Rockauto had a sticker on the outside of them. The filters that I had bought previously from Beemerboneyard do not have this sticker on them. Please be sure to remove the sticker (it peels off easily) and any residue glue before using these filters. The hot oil bath will loosen the glue and you could have this sticker floating in your pan.
I wouldn't want to see anyone have problems from this.
Ron
662,367 miles on touring motorcycles since 1990
IBA 45658 MOA167437
2000 LTC 90600 miles KIA (new)
2003 LTE 164188 miles Silver (Purchased with 1687)
2008 R1200RT 176196 miles (Purchased with 16458)
2017 R1200RT 11145 miles (new)
Total BMW miles 423,984
Goldwing miles 238,383
kellenbenz is offline
post #2 of 29 Old Feb 19th, 2008, 9:22 am
Eric_R's Avatar
Re: Bosch 72161 oil filter WARNING!
Ditto on the sticker. It comes right off. That would be bad in your engine
2002 K1200LTC Ocean Blue
Eric_R is offline
post #3 of 29 Old Feb 19th, 2008, 9:46 am
PMitchell's Avatar
Do they taste like Locktite?
pm
Ride till you can't!
"Der Weg ist das Ziel"
In July, to The Dolomites of Italy, Alps of Switzerland & Austria and returning to Milan via the "Gold Coast" of the French Riveria.
2016 Spain & Portugal
'00 K1200LTC
'90 K75
Sold in '67
PMitchell is offline
post #4 of 29 Old Aug 3rd, 2008, 10:55 am
RVB1019's Avatar
Crap, I saw the sticker and remember this post. Did I remove the sticker----NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Looks like I'm changing the oil again this afternoon.
Rob V.B.
2015 Triumph Explorer 1200
2007 BMW GT (SOLD)
2003 BMW LT (SOLD)
RVB1019 is offline
post #5 of 29 Old Aug 4th, 2008, 8:46 am
RVB1019's Avatar
Well that didn't go well.
I tried removing the old filter yesterday but the oil filter wrench skipped like crazy. I tried the sandpaper/rag/rubber band removal techniques- no dice.
I'm afraid to try the screwdriver technique. I'll bring it in and have someone try that. My question- how bad is it to leave the label on? Other the the obvious reason - the label gumming up the engine.
Have others repeated my mornic move and left the label on? I'm not planning any LD trips just short ones back and forth to work.
Rob V.B.
2007 BMW GT (SOLD)
2003 BMW LT (SOLD)
RVB1019 is offline
post #6 of 29 Old Aug 4th, 2008, 9:25 am Thread Starter
kellenbenz's Avatar
Rob,
Where did you purchase the 72161 filter from? The only ones that I have seen with a label on them came from www.rockauto.com. If you got yours from Beemerboneyard, they have no labels on them so you won't have to worry.
The reason I made this post originally was that I did't see the label on the filter when I installed it. After 3000 miles the label was still partially stuck to the filter, just both ends of it were loose.
I have not had the "filter won't come off problem" but many seem to make it work by using the rag trick. I do know one guy that had to remove the oil pan, but let's hope you don't have to go there.
Ron
IBA 45658 MOA167437
post #7 of 29 Old Aug 4th, 2008, 9:40 am
Originally Posted by kellenbenz
Rob,
Ron
I haven't used the Bosch oil filter, butt I did have a filter that wuz stubborn to remove. I tried and tried to loosen it, butt nearly reduced the ridges to the flats. In desperation, I rotated the wrench clockwise, as if to tighten it, and that seemed to have broken the 'seal' at the gasket, and off it came with a counter-clockwise twist. I don't recall having to use a rubberband or rag, butt may have.
Not sure how the filter got so tightened in the first place - the torque value is pretty low at 11nm. Guess I oughta have my torque wrench calibrated?!!
post #8 of 29 Old Aug 4th, 2008, 11:24 am
RVB1019's Avatar
Yep, Rockauto. I guess I'll cross my fingers, light a candle, slay a chicken in hopes that the label won't screw up my engine.
Rob V.B.
2007 BMW GT (SOLD)
2003 BMW LT (SOLD)
RVB1019 is offline
post #9 of 29 Old Aug 4th, 2008, 11:47 am
JATownsend's Avatar
I've gotten my last few batchs of filters from BBY and they all had the stickers on them. I usually remembered to remove them. Well, a couple of months ago I forgot to remove the sticker.
It dawned on me on a long ride. So, I just rode it. Put 6000 miles on that sticker...NOTHING HAPPENED!
If you forget, or like me, get stupid, don't sweat it!!
J. Averill Townsend
Bloomfield Hills, MI
IBA# 24374
2002 K1200LTC - Silver
JATownsend is offline
post #10 of 29 Old Mar 29th, 2011, 7:05 am
Maineace's Avatar
Rob,
Ron
Yup I had to remove the oil pan on my first oil change, couldn't get the wrench to bra haring all the tricks. Removed oil pan and lo and behold a oil filter with Japanese writing all over it , on a German bike! I was surprised it hand' spun off.
99 K1200 LTC
00' VT 750 Shadow ACE sold
77' Yam XS750 DCrashed
Maineace is offline
post #11 of 29 Old Mar 30th, 2011, 11:07 am
casualemt's Avatar
I bought a stamped metal oil filter wrench from Autozone, it seemed to fit the filter fine until I tried to get the old filter off with it, I realized that it was tight enough to slide on and feel like it was fitting, but any "wrenching" and the darn thing would just slip. I took the wrench into the shop and using the edge of the vice, I took a punch and put one small dimple in each flat on the wrench, took it back out to the bike, and I had to force it onto the filter, but it didn't slip when I poured on the torque..have been using it ever since with great success.
RICH CANNON
2000 K1200LT "a great ride"
1979 XS1100 (gone)
1986 VT500 Ascot (gone)
1972 Honda 500-4 (gone)
1961 Lambretta (way gone)
casualemt is offline
post #12 of 29 Old Mar 31st, 2011, 10:12 am
tonygret's Avatar
I had the "Stuck Filter" syndrome last oil change. I put a piece of fine emery cloth into the filter cup, tapped it on the filter with a plastic mallet. Then VERY slowly turned it off while keeping upward pressure.
I personally don't thing these filter should be torqued. If both surfaces were dry it might be more accurate. But if you put the filter on correctly you are putting some oil on the seal which makes it much easier to turn when going on. Unlike a nut or bolt this is not a real accurate measure of tightness and you end up spinning the filter too much after contact. I now make contact with the gasket and go a bit more than 3/4 turn.
BTW, I have used the BBY filters and have never seen a sticker on them.
tonygret is offline
post #13 of 29 Old Mar 31st, 2011, 9:40 pm
Fountain's Avatar
The instructions printed on the OEM filter say to tighten 1/2 turn after gasket contacts base. That's what I've always done and never had a problem getting the old one off.
beech likes this.
Fountain is offline
post #14 of 29 Old Apr 1st, 2011, 7:33 pm
As long as the torque value takes the lubricated seal into account, this is not a problem. Threads and seals don't have to be dry to get accurate torque.
However, I agree that turning a certain amount after the seal contacts is an easier method and more than adequate for an oil filter.
2007 K1200LT "Starship Enterprise"
VOICE II
Navigator V
Motorrad Communicator
Voyager is online now
post #15 of 29 Old Jun 30th, 2012, 3:57 pm
bluebeam's Avatar
I have used 2 90 deg. Dental picks. punctured the picks thru each side of filter with wide blade flat screwdriver used the screwdriver between the picks to turn the filter.....slicker than snott!!
Tom & Berta
THE EARLY BIRD MAY GET THE WORM
BUT ITS THE SECOND MOUSE THAT
GETS THE CHEEZE FROM THE TRAP!!
bluebeam is offline
post #16 of 29 Old Jul 1st, 2012, 2:02 am
The Bosh filter i use is a 3330.
So there must be two Bosh filters that work?
What's the diff between the two?
Bones1955 is offline
post #17 of 29 Old Jul 1st, 2012, 9:14 am
I know this is not the joke section, but I'm reminded of the following:
Oil Change instructions for Women :
1) Pull up to Jiffy Lube when the mileage reaches 3000 miles since the last oil change.
2) Drink a cup of coffee.
3) 15 minutes later, write a check and leave with a properly maintained vehicle.
Money spent:
Oil Change: $20.00
Coffee: $1.00
Total: $21.00
Oil Change instructions for Men :
1) Wait until Saturday, drive to auto parts store, and buy a case of oil, filter, kitty litter, hand cleaner, and a scented tree, write a check for $50.00.
2) Stop by 7-11 and buy a case of beer, write a check for $20, drive home.
3) Open a beer and drink it.
4) Jack car up. Spend 30 minutes looking for jack stands.
5) Find jack stands under kid's pedal car.
6) In frustration, open another beer and drink it.
7) Place drain pan under engine.
8) Look for 9/16 box-end wrench.
9) Give up and use crescent wrench.
10) Unscrew drain plug.
11) Drop drain plug in pan of hot oil: splash hot oil on you in process. Cuss.
12) Crawl out from under car to wipe hot oil off of face and arms. Throw kitty litter on spilled oil.
13) Have another beer while watching oil drain.
14) Spend 30 minutes looking for oil filter wrench.
15) Give up; crawl under car and hammer a screwdriver through oil filter and twist off.
16) Crawl out from under car with dripping oil filter splashing oil everywhere from holes. Cleverly hide old oil filter among trash in trash can to avoid environmental penalties.
17) Drink a beer.
18) Install new oil filter making sure to apply a thin coat of oil to gasket surface.
19) Dump first quart of fresh oil into engine.
20) Remember drain plug from step 11.
21) Hurry to find drain plug in drain pan.
22) Drink beer.
23) Discover that first quart of fresh oil is now on the floor. Throw kitty litter on oil spill.
24) Get drain plug back in with only a minor spill.
25) Drink beer.
26) Crawl under car getting kitty litter into eyes. Wipe eyes with oily rag used to clean drain plug. Slip with stupid crescent wrench tightening drain plug and bang knuckles on frame removing any excess skin between knuckles and frame.
27) Begin cussing fit.
28) Throw stupid crescent wrench.
29) Cuss for additional 5 minutes because wrench hit bowling trophy.
30) Beer.
31) Clean up hands and bandage as required to stop blood flow.
32) Beer.
33 ) Dump in five fresh quarts of oil.
34) Beer.
35) Lower car from jack stands.
36) Move car back to apply more kitty litter to fresh oil spilled during any missed steps.
37) Beer.
38) Test drive car.
39) Get pulled over: arrested for driving under the influence.
40) Car gets impounded.
41) Call loving wife, make bail.
42) 12 hours later, get car from impound yard.
Money spent:
Parts: $50.00
DUI: $2500.00
Impound fee: $75.00
Bail: $1500.00
Beer: $20.00
Total: $4,145.00
But you know the job was done right!
simoncharles and 58caddy like this.
post #18 of 29 Old Jul 1st, 2012, 10:06 am
bobst2's Avatar
thats a good one dan made me laugh
bobst2 is offline
post #19 of 29 Old Jul 1st, 2012, 12:31 pm Thread Starter
kellenbenz's Avatar
I have put the 3330 and the 72161 side by side and they appear the same. Somewhere on the internet I read that they are the same but made in different countries...one in German the other in the USA.
They both will work in the LT and the R12OO RT....(longer than the RT OEM filter but no problem)
Ron
IBA 45658 MOA167437
post #20 of 29 Old Jul 1st, 2012, 1:26 pm
blueknightga6's Avatar
I've used the 3330/72161 from Beemerboneyard and noticed the sticker was actually on the outside of the box. You could tell it had been peeled off. When I've bought them from Auto Zone they have the sticker on them and I peel it off. It comes off real easy with no residue. So, I'd say that Beemerboneyard just simply takes the sticker off too.
Chris Ehlbeck
blueknightga6 is offline
post #21 of 29 Old Jul 1st, 2012, 2:14 pm
Ron
Thank you1
Cheers!
post #22 of 29 Old May 5th, 2015, 11:55 am
Orcak12lt's Avatar
Just had the same issue and the punch method worked perfect! Thank you.
Robert
Orcak12lt is offline
post #23 of 29 Old May 5th, 2015, 3:49 pm
norton's Avatar
The easiest way if your wrench slips is to put two short self tapping screws through the filter wrench into the bottom of the filter. That will get any filter off no matter how tight it is. I already have holes drilled in the bottom of my wrench for the two self tappers if it slips. But I think most of us over tighten and should stick to the half turn concept.
Scott
2007 LT
norton is offline
post #24 of 29 Old Jul 8th, 2015, 10:21 am
bmwcoolk1200's Avatar
That is a good synopsis. I have to add, slide oil pan out from under car directly behind the passenger front wheel and promptly forget it is there. Back car out and then dump the rest of the kitty litter where you ran over the full drain pan.
SMH
Gordon
Sugar Hill, GA
Signature
bmwcoolk1200 is online now
post #25 of 29 Old Jul 13th, 2015, 9:57 am
amindtat's Avatar
I had a problem getting the oil filter off once. I switched to K&N filters. Problem solved.
58caddy likes this.
amindtat is offline
post #26 of 29 Old Apr 17th, 2017, 9:44 pm
Money spent:
Oil Change: $20.00
Coffee: $1.00
Total: $21.00
17) Drink a beer.
22) Drink beer.
25) Drink beer.
30) Beer.
32) Beer.
34) Beer.
37) Beer.
38) Test drive car.
Money spent:
Parts: $50.00
DUI: $2500.00
Impound fee: $75.00
Bail: $1500.00
Beer: $20.00
Total: $4,145.00
Just saw this.
This was such a long joke I fell asleep halfway through it....was so tired from reading I had to take a nap. http://www.bmwlt.com/forums/images/B..._face_grin.png
I don't know what state has an impound fee of only $75, here in CA is more like $500 if you get towed.
Good joke.
BMW_forever is offline
post #27 of 29 Old Apr 17th, 2017, 9:48 pm
Ron
Hi Ron,
Just saw this post.
It looks like Rock Auto has the 72161 filter but it says it is 72161WS (Workshop). Is that the same filter as the 72161 filter for the K1200LT ??
Thank you.
post #28 of 29 Old Apr 17th, 2017, 10:24 pm
Originally Posted by BMW_forever View Post
Just saw this.
Good joke.
Step 4 was forgotten in the women's section. Here it is:
4) Five miles later, improperly torqued drain plug falls out draining oil and ruining engine. Replacement cost $5,000.
bmwcoolk1200 and Mark65 like this.
VOICE II
Navigator V
post #29 of 29 Old Apr 28th, 2017, 4:55 pm
JWA
JWA's Avatar
I have personal experience that there is also a 5th item for the Women's section
5) loving wife admits she saw the red light come on but thought it was normal because it always comes on when you start the car and kept on running until the car stopped for no apparent reason! CAA (AAA) was called and yearly subscription renewed.
Mark65 likes this.
1999 K1200LT HL Basalt Grey/ Fleximum Sidecar
1983 Silverwing 650 leaner/1987 Velorex Sidecar
JWA is offline
Human Verification
Bosch oil filter 72161 papaed K1200LT 5 Feb 12th, 2008 4:39 pm
2006 R1200 RT oil filter bmotorcycle RT Series 1 Jan 24th, 2008 7:40 am
Bosch Oil Filter Number for our LT's usmctpdog Bike Talk 28 Feb 19th, 2007 2:55 pm
Bosch Premium Oil Filter davek1 K1200LT 11 Aug 16th, 2006 8:15 pm
