Exhaust Removel - BMW Luxury Touring Community
 5Likes
  • 1 Post By DanDiver
  • 3 Post By saddleman
  • 1 Post By GaryEm
post #1 of 16 Old Jun 13th, 2017, 11:54 am Thread Starter
GaryEm's Avatar
Exhaust Removel
It,,s one those things I have not done yet but what does it take to take off the exhaust on the 1200 I like to change my 02 sensor I know I would have to get some gaskets
Gary
2003 K1200LT
GaryEm is offline
post #2 of 16 Old Jun 13th, 2017, 12:24 pm
bmwcoolk1200's Avatar
Re: Exhaust Removel
It is not very difficult. I think it is a 14mm deep socket and a wrench to get the manifold nuts off. Some of the studs may come out and that is OK. Then there is the rear support for the exhaust and I think it will just slide out with a little lube on the rubber parts.
To get the old copper rings out, some sort of hook to catch on them and pull them out helps as they can get wedged in pretty good.
Depending on how the O2 wires are routed, you might need to pull off the reverse knob mount if it is behind it. If you have no desire to hang on to the old sensor, you can just cut the wires and pull it out but it is nice to have an intact spare if it still works relatively well. If it is routed in front, disregard this step.
Use plenty of copper anti-seize when installing the new one even if the replacement already has some on it. Some can be a buggar to get to break lose so use heat.
Be careful installing as in my book, the table has the incorrect torque value of 44 Ft Lbs and that will tear the flanges off or strip out the studs. The correct value is 16 Ft Lbs.
Gordon
Sugar Hill, GA
Signature
bmwcoolk1200 is offline
post #3 of 16 Old Jun 13th, 2017, 3:06 pm Thread Starter
GaryEm's Avatar
Re: Exhaust Removel
Thanks Gorden its nice info on the torque I got one those mean Irwin 53916 impact bolt grip from amazon its got great reviews on getting sensors out like straight five stars
Also thanks on how to get the exhaust off
Gary
2003 K1200LT
GaryEm is offline
post #4 of 16 Old Jun 13th, 2017, 3:10 pm
vernvernvern's Avatar
Re: Exhaust Removel
Clymer is your friend.
Bought used K1200LT number 3. This one is green/teal with 31,369 miles and is an '02. The first 2 bikes made it to near 150,000 miles.
Due to heart health, the Dr says not to ride under 40 degree air temp. Ugh! Guess that'll stop my 20 degree rides from now on.
76 years young!
Converted HD rider.
Vern
vernvernvern is offline
post #5 of 16 Old Jun 13th, 2017, 3:24 pm Thread Starter
GaryEm's Avatar
Re: Exhaust Removel
I do have clymer book I guess I just wanted to here from someone that did it
Gary
2003 K1200LT
GaryEm is offline
post #6 of 16 Old Jun 13th, 2017, 3:29 pm
Re: Exhaust Removel
Yep, that's OK.............. good idea as this site is the best.
76 years young!
Converted HD rider.
Vern
post #7 of 16 Old Jun 13th, 2017, 4:32 pm
Super Moderator
dfinazzo's Avatar
Re: Exhaust Removel
Be prepared for some of the nuts to hang on to the studs as sometimes they have a tendency to pull the studs out of the aluminum block.
I would use BP Blaster for several spray sessions . . . maybe some localized heat!!
Other than that it's just a bolt here and screw there exercise.
Dan Finazzo
dfinazzo is offline
post #8 of 16 Old Jun 13th, 2017, 5:06 pm
Re: Exhaust Removel
I'm pretty sure that you do not have to remove the exhaust to install the 02 sensor. Might double check before going to the trouble.
Here is a hint though if you do. To replace the headers, where they attach to the engine, there are copper gaskets that have to be held in place. A dab of grease will keep them in place while you screw in the bolts.
Voyager likes this.
post #9 of 16 Old Jun 13th, 2017, 5:07 pm
Enjoy The Ride
saddleman's Avatar
Re: Exhaust Removel
I change the O2 with the exhaust still on.
DanDiver, Voyager and beech like this.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #10 of 16 Old Jun 13th, 2017, 7:20 pm Thread Starter
GaryEm's Avatar
Re: Exhaust Removel
Well Dave I better tell you the rest story I was in there to grease the 4 joints on the linkage and thought to myself why not change the sensor why I am there how hard can it be Did not go so good I stripped the sensor so I grease the linkage and put everything back together and plugged my sensor back and am riding it But I am having issues like Axle did in a thread like he said cough and flutter and stumbling for a long time he put a sensor in and did cured it
So now I am getting prepared for the next try by taking the exhaust off order a( irwin tool 53916 impact bolt grip) off amazon a five star review for getting sensor out Or I might TRY once again with the tool I am getting by just taking linkage out of there but this it will be on my lift
bmwcoolk1200 likes this.
Gary
2003 K1200LT
GaryEm is offline
post #11 of 16 Old Jun 14th, 2017, 8:15 am
Re: Exhaust Removel
What do you mean by "stripped" the sensor? This generally refers to removing the threads on a fastener. Do you mean you rounded off the hex shape on the sensor? I try to always heat the sensor fitting up and then soak it well with penetrating oil. Let that sit overnight and often the sensor will come out fairly easily. If not, heat it up and try again.
Hint: don't use the O2 sensor socket for removal. The slot weakens it substantially and it will spring open and round the hex fitting or break the socket. Best to cut the sensor wire short and use a 6 point impact socket. They are very robust.
If you have rounded off the hex corners, use a big pipe wrench to remove the old one.
2007 K1200LT "Starship Enterprise"
VOICE II
Navigator V
Motorrad Communicator
post #12 of 16 Old Jun 14th, 2017, 12:09 pm
Enjoy The Ride
saddleman's Avatar
Re: Exhaust Removel
I have always used a box end wrench to remove them.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #13 of 16 Old Jun 14th, 2017, 3:28 pm Thread Starter
GaryEm's Avatar
Re: Exhaust Removel
I rounded the hex corners off Has there anyone that actually messed up threads in the exhaust
GaryEm is offline
post #14 of 16 Old Jun 14th, 2017, 4:05 pm
mcracer's Avatar
Re: Exhaust Removel
I removed my 02 sensor and re-installed it into a REMUS exhaust and stainless header. It was TIGHT! I used a propane torch to put some heat around the threads. Fine line between heating the thread and over-heating the sensor. I moved it, put a slight hand torque on it, works just fine. Header stud bolts got an overnight soaking of liquid wrench. Brass gaskets will need to replaced if you remove the entire system. After installing the header and gaskets, I went back under the bottom and made sure the nuts were tight after a few times of heating and cooling the system with normal riding. One of my studs was completely missing from the PO, so I make sure everything is staying put with regular visual inspections.
2000 BMW K1200LT
2001 Kaw Concours zg1000
2001 Kaw KX250
1974 Kaw KX250
1981 Yam YZ465
mcracer is offline
post #15 of 16 Old Jun 14th, 2017, 4:08 pm
james216's Avatar
Re: Exhaust Removel
I heated mine(O2) with map gas. Sprayed it with Aerokroil. Resprayed a few times that day. The next day with a 6 point box wrench. And a little persuasion. It came out without to much difficulty. Dummy me. I pulled the leader string out instead of tying off. So rerouting the cable was a B@#th.
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #16 of 16 Old Jun 14th, 2017, 5:36 pm
Enjoy The Ride
saddleman's Avatar
Re: Exhaust Removel
I have replaced several & so far have never had the threads in the exhaust get messed up. I have had to heat a few to get it loose.
Dave Selvig
2004 Black LT
2000 Canon Red LT
Human Verification
Trading Exhaust Systems stevea2980 K1200LT 8 Sep 7th, 2013 10:38 pm
Exhaust Rattle - Solution and some photo explanations AAX94 K1200LT 5 May 22nd, 2012 12:14 pm
2010 RT exhaust leak BigKev RT Series 8 Dec 22nd, 2010 6:06 pm
Cracked exhaust and vibration bowlesj K1200LT 2 Aug 4th, 2009 11:48 am
'07 R1200RT exhaust upgrade switz RT Series 3 Mar 11th, 2008 6:34 pm
