2005 K1200LT RAM Mount - BMW Luxury Touring Community
 1Likes
  • 1 Post By james216
post #1 of 13 Old May 12th, 2017, 11:56 am Thread Starter
I am trying to add a RAM mount to my bike to hold a cell phone or GPS. The dealer advised me to remove the BMW logo just above the radio buttons and I would find a bolt underneath. I removed the logo and all I have is plastic, no hole, no bolt. Has anyone else had this problem? I prefer not to improvise a fix, I like things done right. This seems like the idea spot but how do I proceed? I dont want to glue it in place, I prefer a more "permanent" mount.
Thanks!
PSobz is offline
post #2 of 13 Old May 12th, 2017, 12:54 pm
bmwcoolk1200's Avatar
Re: 2005 K1200LT RAM Mount
If I remember doing mine and the 05 is the same as the 01, there is a screw accessible from underneath the stingray possibly under a sticker or maybe not. What I had to do after separating the pieces of the stingray slightly, I drilled progressively larger holes all the way through large enough for the ram ball mount bolt. Then I bought some stainless washers about the size of the logo and placed one on top for strength and also places a stack large enough to get some tightness top to bottom on the inside of the stingray and another underneath so when compressed, it didn't break the plastic but was able to be adequately tightened so not to move around.
You will be drilling out the screw mount formed on the top piece on the underside of the stingray under the logo so you lose any center support for tightening the ram mount. I removed the other screws holding top to bottom enough to separate it and see inside. I fished a string through the bottom and pulled it out the side through the washer stack and then back out the top to hold the washers in place while I got the bolt through it all and into the ram mount. Took a little patience but it works well when done and yes, it is the ideal place.
Signature
Gordon
Sugar Hill, GA
2001 K1200LTI – Champagne (current ride)
bmwcoolk1200 is online now
post #3 of 13 Old May 12th, 2017, 1:00 pm
I use the offset ones that attach to the brake/clutch reservoir covers - works great
http://www.rammount.com/images/galle...-B-346UIU3.jpg
eelmgren is offline
post #4 of 13 Old May 12th, 2017, 1:14 pm
I have one of those also. there is also one that can be fitted to the mirror holes on either side but many people actually use those for mirrors so they may not be available. I do like having my GPS low, front and center, mounted where the OP is attempting with a stingray mount.
Signature
Gordon
Sugar Hill, GA
post #5 of 13 Old May 12th, 2017, 4:31 pm
I mounted mine right above the radio controls. Took the BMW emblem off, and fabricated a 90 degree bracket. Chose a Marlin Chrome mount instead of the Ram. Much sturdier, and actually looks like it's hard to steal compared to the Ram. Someone would have to know how to spread the arms to take the phone out. It's pricey, but really a beautiful mount.
When i took the emblem out, i saw a hole going thru the Stingray, and just used self adhesive tape and a longer screw threw the hole. Slightly bigger of course, and it's held perfectly. No vibration, and easily gotten to. The Marlin's mount can be ordered with many different mounting options. I've used it for years, first on my Harley, then the RT, then the LT. No rust, and holds the phone very securely.
ID:	126265   Click image for larger version
Name:	iphone side view.gif
[/SIGPIC]
Joe
Palm Coast, FL.
2006 K1200LT (Love it)
2002 R1150RT (Sold)
2007 Harley FLHTCU (sold at 137k Miles)
1999 Harley Night train (blew the eng at 150k miles)
1986 harley Davidson FLTC (Sold When assigned to Europe
1982 Harley Wide Glide (sold)
1981 Kawasaki k1000LTD (sold)
1980 Triumph Bonneville (sold)
BeemerJoe is offline
post #6 of 13 Old May 12th, 2017, 10:23 pm
Munmi's Avatar
I removed the BMW logo above the radio, as you describe, to install my gps unit. Drilled a 1/4 inch hole clear through then inserted a 1/4 inch hex bolt from the bottom so the threads were sticking up to the height I needed for installing my L-bracket (DIY project). I used this technique on both the 2002 and the 2004 LTs. Sorry I don't have photos readily available.
Scott and Theresa
Munising, MI
2004 K1200LT Black
2014 Kawasaki KLR650
Munmi is offline
post #7 of 13 Old May 12th, 2017, 10:48 pm
Here are a couple pictures of the ram ball mount through the stingray from the bottom with removal of the BMW emblem now that I am home and can take some to show.
ID:	126281   Click image for larger version
Signature
Gordon
Sugar Hill, GA
post #8 of 13 Old May 13th, 2017, 6:40 am
Munmi. I just used a longer self tapping screw and went thru the stingray, that way i didn't have to remove the tupperware. Plenty of room under the stingray.
[/SIGPIC]
Joe
Palm Coast, FL.
2002 R1150RT (Sold)
post #9 of 13 Old May 13th, 2017, 9:17 am
davebullock's Avatar
I have a Zumo 550 as well, and mounted it on the same place on the stingray, but used some heavy duty epoxy. It has sat there now for about 4 years, through every season/etc., and is rock solid. I realize that it is permanent, and perhaps not the prettiest installation, but it works just fine. Behind the tank bag, you can't see it, and it's mounted low enough for me to see the full dash controls. I had it on the clutch reservoir for a start, but didn't like it.
ID:	126297   Click image for larger version
ID:	126305   Click image for larger version
48 states
2000 LT 165,000 miles
2007 RT P 42,000 miles SOLD
1982 vision 550 Yamaha SOLD
1966 Honda CL77 (2016-17 winter project)
Four corner Iron Butt ride
48 state/12 day ride 2016
davebullock is offline
post #10 of 13 Old May 13th, 2017, 12:56 pm
james216's Avatar
Thanks!
I got a clutch cover ram mount. And mounted my zumo 550 & cb radio to it. I can't seem to attach pics. Send me a private message. I'll send to your phone if you like.
randy morrow likes this.
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is online now
post #11 of 13 Old May 18th, 2017, 2:57 pm
Hey James, what cb do you use, i have a handheld midland and need to mount it. Just got this bike 2000 k1200lt, looks great for a 17 year old bike.....
randy morrow is offline
post #12 of 13 Old May 19th, 2017, 6:14 pm
Check with J&M® Motorcycle Audio they used to have a system for a handheld CB. I just took a quick look and didn't see it, but in years past I have had one of these units and it worked great. Check their website and give them a call and tell them what you need. Also check with Sierra Electronics. Good Luck.
Leon
Notahog is offline
post #13 of 13 Old May 19th, 2017, 8:46 pm
Munmi's Avatar
I didn't need to remove the stingray either. Yes there was plenty of room for the 1/4 x whatever I used to insert from the bottom up.
Scott and Theresa
Munising, MI
2004 K1200LT Black
Munmi is offline
Human Verification
2005 K1200LT questions (new guy) rangemaster K1200LT 10 Dec 15th, 2014 5:45 pm
iPhone Navigation & Mount on K1200LT rpwade K1200LT 7 Oct 10th, 2013 8:28 pm
Shock Mount Hardware 2005 K1200LT deputy5211 K1200LT 2 Sep 7th, 2012 9:33 pm
Swap 2005 engine to 2002 K1200LT? john_loucks K1200LT 8 May 4th, 2012 3:14 pm
