Replaced speed sensor - BMW Luxury Touring Community
 4Likes
  • 1 Post By Voyager
  • 1 Post By dvpadgett
  • 2 Post By MBiker
post #1 of 7 Old Mar 19th, 2017, 7:00 pm Thread Starter
1999 LT New bike for me. Speedometer was not working when purchased from a friend. Purchased new sensor and replaced.
Speedometer worked while on center stand....just a few spins to see if it worked(snow outside could not test ride.) Finally took bike for quick
spin only got as far as a few blocks and speedometer stopped working. Any ideas? thanks New Guy
MBiker is offline
post #2 of 7 Old Mar 19th, 2017, 8:45 pm
Re: Replaced speed sensor
Did you trace the wires at least past the swingarm? I recall some issues with the sensor wire breaking near an overly tight zip tie on or near the swing arm pivot. A broken wire nearing a point of movement can cause intermittent faults as the two broken wire ends make and break as the part moves.
Patric likes this.
2007 K1200LT "Starship Enterprise"
VOICE II
Navigator V
Motorrad Communicator
post #3 of 7 Old Mar 20th, 2017, 3:10 am
Enjoy The Ride
saddleman's Avatar
Now & then the speed sensor wheel in the final drive have come off.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #4 of 7 Old Mar 20th, 2017, 9:25 am
I had the same problem when I purchased my bike a few years ago. It turned out that the wires were damaged because of the zipties. You can re solder the wires once you determine where the break occurred.
beech likes this.
dvpadgett is offline
post #5 of 7 Old Mar 22nd, 2017, 1:28 pm Thread Starter
Thanks for the replies. This weekend Ill look over the wiring. But since it was a new sensor, I feel that wiring should be fine, but i will look at the rest of the wiring. Second
I have a feeling it might have to do with the piece in the final Drive. Will get Back.
Thanks again.
MBiker is offline
post #6 of 7 Old Mar 22nd, 2017, 8:20 pm
Easy enough to check. Just pull the sensor back out and gently try to move the exciter wheel with a small stir stick. It should not move at all unless the wheel moves.
2009 K1300GT
2005 Ocean Blue Blue Wizard
CCR 06 Braselton CCR 07 Osage Beach CCR 08 Midway
CCR 09 Rapid City CCR 10 Killington, VT,CCR 11 Boise, CCR 12 Duluth
CCR 2013 Bend, CCR 2014 Backyard! CCR 2015 Couer d'Alene
post #7 of 7 Old Apr 2nd, 2017, 5:15 pm Thread Starter
Wink Re: Replaced speed sensor
OK feeling like a newbie . Went to check sensor and realize that when I replaced it I didn't screw down the sensor all the way. Had a phone call when I was doing it and forgot to finish. Well..... tightened screw's and now my speedo works.....somethings are just so simple. Thanks for the help.
Patric and bmwcoolk1200 like this.
MBiker is offline
Human Verification
How fast is too slow bmwcoolk1200 Chit Chat 18 Oct 9th, 2016 9:34 am
Transmission Speed Sensor Dochie K1200LT 8 Jul 3rd, 2014 8:32 am
Instrument backlight -- light sensor problem? SPXDR RT Series 8 Dec 14th, 2011 12:26 am
Section speed trap in The Netherlands vvk Europe 4 Apr 18th, 2006 3:40 am
Speed traps in The Netherlands vvk Chit Chat 0 Oct 24th, 2005 9:38 am
