Anyone use PIAA 74121 Driving Light Mounting Bracket? - BMW Luxury Touring Community
 5Likes
  • 1 Post By mcracer
  • 1 Post By bmwcoolk1200
  • 2 Post By EzyMount
  • 1 Post By mcracer
post #1 of 23 Old Apr 7th, 2016, 12:44 pm Thread Starter
mcracer's Avatar
I'm going to put some LED driving lights on the upper front of my 2000 KLT. I want them mounted on the inside upper front.
Has anyone used these mounting brackets from PIAA? They say "made vehicle specific" but there are no reviews on any site that I can find. PIAA is very well known and proud of their stuff "$$$". I found these on amazon for $60 new. Seem like a good deal to accomplish my goal without fabricating them myself.
I had some fork mounted lights on my K75 years ago and they stayed tight and gave me years of service. The upper fairing mount will eliminate the issue of vibration and front tire changes.
Anyone have some pictures of what they look like installed. The picture below has the brackets hidden in the shadows. Thanks
Name:	piaa 74121 mount 2.jpg
ID:	102506   Click image for larger version
Name:	piaa 74121 mount.jpg
2000 BMW K1200LT
2001 Kaw Concours zg1000
2001 Kaw KX250
1974 Kaw KX250
1981 Yam YZ465
mcracer is offline
post #2 of 23 Old Apr 7th, 2016, 1:06 pm
r75
Re: Anyone use PIAA 74121 Driving Light Mounting Bracket?
I believe that these were developed and manufatured by a meber of this forum ad are mostly NLA. I use them IMO are the best design and the highest quality for the K1200LT
Bill
1999 K1200LT
2002 K1200RS
r75 is offline
post #3 of 23 Old Apr 7th, 2016, 1:45 pm
bmwcoolk1200's Avatar
Mark, I about choked at the pride PIAA has for their lights and as good as they are, I just couldn't bring myself to pay that much. I ended up buying these and mounted them under the bumper wings and they are quite bright, 900 lumens each. Just want to throw these out there as they might work with that mount up under the front.
Amazon.com: Mini Trail Lights OZ-USA (TM) LED CREE Spot Motorcycle Offroad Dual Sport Enduro Fog KTM Hid: Automotive
I too wanted some more light shining forward for visibility and they do a pretty good job of lighting the road up close being mounted that low. I made the mounting plate and ignore the scuffed up bumper. Most of that was the PO. Most
ID:	102530   Click image for larger version
Signature
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #4 of 23 Old Apr 7th, 2016, 2:16 pm
Post #2 has some pretty good pictures.
PIAA 1100X Mounts
Signature
Gordon
Sugar Hill, GA
post #5 of 23 Old Apr 7th, 2016, 2:56 pm Thread Starter
mcracer's Avatar
Hey Gordon; I didn't say I was going to use their lights! I too think they are over-priced. The lights I want to use are the exact ones you have in your link. Great Minds! I want them mounted inside the front fairing. Thus, PIAA mounting brackets.
Thanks for finding the LINK. That's what I was looking for.
bmwcoolk1200 likes this.
2000 BMW K1200LT
2001 Kaw KX250
1974 Kaw KX250
1981 Yam YZ465
mcracer is offline
post #6 of 23 Old Apr 7th, 2016, 3:04 pm
There are some that look the same and cost less but only boast 800 lumens each. No idea if they are the same or not.
I ordered another set that was brighter but I didn't read the fine print and they have 3 modes ( like the flashlights) and I wasn't going to put a switch on them specifically beyond the accessory relay connection so I couldn't flip them on and off to get them from mode to mode and I certainly didn't want a flashing mode.
Send pics if you go ahead with it.
mcracer likes this.
Signature
Gordon
Sugar Hill, GA
post #7 of 23 Old Apr 7th, 2016, 6:36 pm
EzyMount's Avatar
Just make sure, whatever light you mount on my old bracket, that it's footprint and relative space occupied is no larger than the space that would have been occuppied by the PIAA Lamp housing..especially in the vertical...
bmwcoolk1200 and mcracer like this.
Jim Lawson 2016 R1200RT
Retired to NC !
EzyMount is offline
post #8 of 23 Old Apr 7th, 2016, 8:07 pm
Jim, may I assume you are the designer of the said bracket? If so, do you have the specs of the PIAA light vertically? The trail OZ LED lights measure 3 - 3/4 inches from the bracket down to the lowest point on the front of the light.
Signature
Gordon
Sugar Hill, GA
post #9 of 23 Old Apr 7th, 2016, 8:42 pm
EzyMount's Avatar
body measures appx 2 & 3/16's outer edge to edge. that will not include on a vertical scale from base of foot to bottom of light. I have some spare lights in garage, can measure precise distance for you tomorrow...
Retired to NC !
EzyMount is offline
post #10 of 23 Old Apr 7th, 2016, 8:59 pm
OK, the measurement I took was from the top of the mount down to the lowest point on the light.
Signature
Gordon
Sugar Hill, GA
post #11 of 23 Old Apr 7th, 2016, 9:29 pm
EzyMount's Avatar
That is not accurate for the PIAA 1100X light body. My point was, bracket design was developed and light was placed on bracket at a position where there would be adequate clearance during all normal operations, including full turn lock. Anything exceeding that vertical dimension/height may produce fender contact at some time under some conditions....
Retired to NC !
EzyMount is offline
post #12 of 23 Old Apr 7th, 2016, 10:16 pm
I understand that. That is why we need the PIAA dimensions to compare them with the OZ light bodies. They may not be compatible as far as fitment but if they are, they would be a good lower cost substitute.
Signature
Gordon
Sugar Hill, GA
post #13 of 23 Old Apr 8th, 2016, 2:56 pm
ebear695's Avatar
just measured my piaa 1100 on that mount, it is 2 3/4 inch. from the bracket to the light, don't think I would put an inch longer light on them
Eddee P
Bronze God on a Steel Stallion
2001 K1200LT, Champagne with all the STUFF, and R1100RT ft fender, cool
2008 R1200 RTP (retired)
2002 R1150 RTP (retired)
2007 Honda Silverwing
2007 Suzuki Burgman AN650ex
2001 Ducati ST4
1997 KZ1100 (totaled) Motors are cool,
CMTO 8 yrs
We sleep peacefully in our beds at night because rough men stand at the ready to visit violence on our behalf....George Orwell
ebear695 is offline
post #14 of 23 Old Apr 8th, 2016, 9:17 pm Thread Starter
mcracer's Avatar
Thanks for the feedback. Those are real numbers. I was concerned about the clearance. I think the LED lights that Gordon has mounted and measured could be modified "a little". We shall see.
Q; Are there any other "reasonably priced" 900 lumen LED lights that anyone has used? Are there any other options for those brackets?
Nice brackets! I like the location and I'm determined to have lights mounted on them.
2000 BMW K1200LT
2001 Kaw KX250
1974 Kaw KX250
1981 Yam YZ465
mcracer is offline
post #15 of 23 Old Apr 9th, 2016, 10:32 am
EzyMount's Avatar
I still have a few sets of these brackets out in the garage. Could not throw them away after closing down. Anyone needs some, let me know. I will let them go for $25 each set, plus s&h....
Retired to NC !
EzyMount is offline
post #16 of 23 Old Apr 9th, 2016, 11:25 am
MartyBlok's Avatar
I have those brackets on my bike with some little led light that I got off eBay. They don't really put out much light to drive by but that wasn't what I was looking for. I wanted to be seen and my riding friends tell they really help with visibility. I had some Hella lights on there at first and I think on a big bump they would hit . No problems with these lights.
Marty Blok
99 LT
MartyBlok is offline
post #17 of 23 Old Mar 17th, 2017, 9:48 pm
Do you still have any mounts that you would sell?
David Brackett is offline
post #18 of 23 Old Mar 18th, 2017, 8:46 pm
EzyMount's Avatar
Yes, sent yu PM
EzyMount is offline
post #19 of 23 Old Mar 19th, 2017, 7:41 am
Yes, sent yu PM
Thanks for the response. I am unable to respond to your PM because I have not posted enough in the forum yet. Please send me a PM with how much$ and a method of paying.
David
post #20 of 23 Old Mar 19th, 2017, 8:39 am
EzyMount's Avatar
PM sent
EzyMount is offline
post #21 of 23 Old Mar 31st, 2017, 9:40 am
BMWCharlie's Avatar
Hi, I have those exact brackets which were perfect for the old and discontinued PIAA units shown in the photo. I replaced the units with new LED 270s. Those brackets fit the bike perfectly, but they don't fit the much larger 270s. I'm trying to fabricate an attachment to fit. In fact, that's #1 on tomorrow's to-do list.
Charlie
99 K1200LT
85 R80RT
81 R100RS (Sold it 4/10)
03 Moto Guzzi V11 LeMans
BMWCharlie is offline
post #22 of 23 Old Mar 31st, 2017, 1:58 pm
EzyMount's Avatar
When mounting larger diameter lights around the fender area, be cautious and allow adequate clearance for fork movement in all directions. Ride safe....
EzyMount is offline
post #23 of 23 Old Apr 1st, 2017, 1:32 am
trussell's Avatar
I have them on my bike.
And currently I have the fairings off, so if I can help with precise measurements, let me know
trussell is offline
Human Verification
garmin navagation11 mounting bracket ivan GPS 1 May 5th, 2008 8:56 pm
How many forum members does it take to change a light bulb? RoyvL Humor 12 Feb 13th, 2006 12:49 pm
PIAA light bulbs king Lighting 11 Nov 21st, 2005 11:22 pm
Light mounting options for 1990 K100LT? RickBlanc Other K-Bikes Discussion 2 Oct 24th, 2005 3:05 pm
